4 speed stuck in 2nd - Pontiac GTO Forum
post #1 of 16 (permalink) Old 11-14-2018, 09:03 AM Thread Starter
MidnightAuto's Avatar
Hey guys- had an odd thing now happen twice over last month. I punch it in 2nd and when I go for 3rd gear it does not happen. The transmission is then stuck in 2nd. Driven home twice in 2nd now. I don’t know much about 4 speeds (it’s an m20). I get under the car and pull the middle rod (I think it’s 1/2 rod) back towards trunk and it frees up the shifter and I am back in business. Any thoughts on how I should troubleshoot? Thanks guys..
MidnightAuto is offline
post #2 of 16 (permalink) Old 11-14-2018, 12:20 PM
BLK69JUDGE's Avatar
Quoted: 71 Post(s)
shift in a H pattern not a Z
you have to come straight up to nuetral out of second
then cross over to 3rd
your cutting the corner
or your linkage needs adjusting ....
or
both
original or repop linkage ?
ever put the pin in the guide hole and adjust the rods ?
scott
BLK69JUDGE is online now
post #3 of 16 (permalink) Old 11-14-2018, 02:22 PM Thread Starter
thanks for help judge. no one told me the H was for real. I am shifting diagonal. how do you shift an H fast!?
With that said, I suspect maybe my linkage needs to be adjusted too. I don't know if its original or repop. PO made the car pretty much period correct but not numbers matching. How would I tell if repoo? I dont know about the pin guide - although I do have the shop manual and recall seeing a pin guide in the schematic. is it easy to describe what I am generally supposed to do adjust the linkage?
one other thing to mention that may support linkage adjustment - shifting even when just cruising is sometimes not smooth - i have to baby it into second sometimes as I get some initial resistance
post #4 of 16 (permalink) Old 11-14-2018, 08:09 PM
RMTZ67's Avatar
Quoted: 83 Post(s)
Stuck in 2nd
Originally Posted by MidnightAuto View Post
Hey guys- had an odd thing now happen twice over last month. I punch it in 2nd and when I go for 3rd gear it does not happen. The transmission is then stuck in 2nd. Driven home twice in 2nd now. I donít know much about 4 speeds (itís an m20). I get under the car and pull the middle rod (I think itís 1/2 rod) back towards trunk and it frees up the shifter and I am back in business. Any thoughts on how I should troubleshoot? Thanks guys..
I thought I was the only one that had that problem. But mine is on my 1974 camaro Z28 not my Gto. I have a rebuilt 4 speed muncie and a rebuilt oem itm shifter. I thought it was my shifter but now I think it may be my trans or linkage. I Have set my linkage with a allen tool thru the shifter in neutral several times with no luck. Mine has never done it while driving only when I am trying to get it in reverse. hopefully someone has solved this issue.
RMTZ67 is online now
post #5 of 16 (permalink) Old 11-14-2018, 08:40 PM
11th Indian's Avatar
Quoted: 26 Post(s)
had that problem with my Muncie 3 speed. Would also jam between gears.
The linkage was out of adjustment
One of the shifter arms was worn and rotating on the shifter ear (moving the shifter wasn't moving the shifter fork in the transmission)
The bolt holding the shifter arm was the wrong depth.
Took care of the adjustment, had the arm welded and I drilled it out and used the correct bolt size and some loctite red.
Working fine since.
11th Indian is offline
post #6 of 16 (permalink) Old 11-14-2018, 08:52 PM
BLK69JUDGE's Avatar
Quoted: 71 Post(s)
something to try........
always go into first before going into reverse
reverse uses several 1st gear gears and parts
jumpin from any other gear they can be moody
and it really helps to go into 1st the around the corner to reverse
just have to remember tom come all the way out of first brfore doing the loop to reverse .....
Scott
post #7 of 16 (permalink) Old 11-14-2018, 08:53 PM Thread Starter
ha. yeah its annoying. I did just pull out the shop manual and believe i now understand how to adjust the linkage with the pin. I assume I can use anything that fits in the hole - like an allen wrench or similar. will update any progress. supposed to snow tomorrow. lets see how the weather holds up...
post #8 of 16 (permalink) Old 11-14-2018, 08:57 PM Thread Starter
thanks Indian. ill look at the rod and the ear too and see if any play or movement that may lessen shift action
post #9 of 16 (permalink) Old 11-15-2018, 04:25 PM
Quoted: 119 Post(s)
Shifter/linkage out of adjustment. Line the arms up with a 1/4" drill in the hole with the shift rods off, then adjust the rods to fit. Remove drill bit. Also, the shift arms that connect the linkage to the shift forks inside the trans can come loose on the earlier linkage. This is easily tightened on the outside of the box where the arms connect with the linkage. With a Muncie and a Hurst shifter, I simply slam the shifter from 2nd towards the passenger side wing window....straight diagonal shot. Nobody follows the 'H' pattern, unless they like losing races and going slow. There are all kinds of youtube videos on shifting one of these cars....if you're brave, queue up Bill "Grumpy" Jenkins powershifting his '69 Camaro. Absolutely bitchin'....and brutal.
post #10 of 16 (permalink) Old 11-15-2018, 05:56 PM Thread Starter
Magic. How about the cigar.
https://m.youtube.com/watch?v=ocC8MueSs_A
Powerglide stuck in 2nd gear? ERIC60 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 06-17-2017 11:10 AM
68 gto 4 speed stuck in second gear! Help! mwinters 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 11-02-2014 08:11 AM
66 4 speed stuck in 1st xconcepts 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 09-08-2014 11:13 AM
66 gto muncie 4 speed vibration / rattle in shifter "at speed" take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 10-28-2010 08:43 PM
66 gto 4 speed stuck in gear? auburnconsulting 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 30 03-11-2009 04:36 PM
