4 wheel drive - Pontiac GTO Forum
post #1 of 7 (permalink) Old 10-20-2011, 06:52 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
4 wheel drive
not exactly a GTO question, but I use an F350 w/ 4 wheel drive to tow it around so here it is.
My front tires wear so that on the outside is WAY more worn than the inside.
several have told me this is normal on FWD's. Is this true?
Y'all"s the smartest folks I've ever known.
thanks as always
ps still hung over from vegas...........
party:
Topkat is offline
post #2 of 7 (permalink) Old 10-20-2011, 09:00 AM
Quoted: 99 Post(s)
TK, a lot of those Fords eat tires. The ones with Twin-I-Beam and the ones without. Aftermarket camber correction kits are available and can be installed by a competent alignment tech. They are labor intensive and they are not cheap, but are a permanent fix for the tire wear problem. Just had this done on my GF's Ford van she uses for her business and the tires are straight up and down now and are wearing fine, no longer on edge.
post #3 of 7 (permalink) Old 10-20-2011, 02:09 PM
likethat's Avatar
How many miles? Is it a dually? I have own 3 ford 4x4 all single wheel and single cab. All 3 has a 460, 1 auto 3 speed, 1 4 speed manual, and 1 5 speed manual.
67 GTO H.O. Convert 4spd
likethat is offline
post #4 of 7 (permalink) Old 10-20-2011, 02:16 PM
likethat's Avatar
I know the older Fords had a fixed camber sleeve where the Chevys have an adjustable one. I have rebuild many Ford and Chevy front ends. The camber sleeves can be a really big Bia to get out. Why is it every car or truck I own needs new suspension, tires, and brakes?
likethat is offline
post #5 of 7 (permalink) Old 10-30-2011, 01:38 PM
jetstang's Avatar
I do fleet maintenance on the HD rental trucks, 08 or so F350s. They wear the outside of the tires within 5k miles and get cupped up and need frequent rotating. My theory is, big truck with tight turning radius, so you are trying to get out of a tight spot with the steering wheel at lock, the accelerating thus pushing the tire sideway and scrubbing the outers off of the tire. Also some bad geometry in the suspension.
Burning rubber since 1982!!
jetstang is offline
post #6 of 7 (permalink) Old 10-30-2011, 04:04 PM
facn8me's Avatar
Common on a ford. Nothing to do with 4wd. I get 60k out of the tires on my lifted cheby. Of course my spare matches and I rotate all 5 which helps.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #7 of 7 (permalink) Old 11-01-2011, 08:08 AM
66tempestGT's Avatar
rotate often.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
out for a drive REDGTO89 2004-2006 GTO General Discussion 12 03-18-2009 03:02 PM
Sex Drive GOATTEE 1964-1974 Tempest, Lemans & GTO General Discussion 14 11-07-2008 01:53 PM
Left Vs Right wheel drive sutliffhl21 Interior Discussions 16 06-24-2006 10:49 PM
Front Wheel Drive GTO AA950 Service, Maintenance and Technical Discussion 15 10-31-2005 12:14 PM
