400 or 455? - Pontiac GTO Forum
post #1 of 10 (permalink) Old 01-20-2008, 10:30 PM Thread Starter
rod collins's Avatar
400 or 455?
I'm getting ready to build another engine for my 66 gto Cannot decide which would work the best 400 or 455. Any body have any suggestions? I already have a set of 670 heads and a set of 455 4x. Also have a roller cam 236/224 @.50.
rod collins is offline
post #2 of 10 (permalink) Old 01-21-2008, 03:31 AM
Is the 400 a 9786133 casting from 1967? If so what is the letter code?
05GTO is online now
post #3 of 10 (permalink) Old 01-21-2008, 07:15 AM
If the 400 is the correct block for the car I would do that, if not, then the 455 would be getting the treatment.
post #4 of 10 (permalink) Old 01-21-2008, 08:50 AM
389 would be correct for 66, the 400 with 670 heads would allow for more HP, the 455 with the heads listed will have a lower CR and they have smaller valves.
05GTO is online now
post #5 of 10 (permalink) Old 01-21-2008, 09:03 AM
How about the 400 heads on the 455 block? Could he do that?
post #6 of 10 (permalink) Old 01-21-2008, 09:14 PM
SANDU002's Avatar
Yes. I have a 455 block w/670 heads in my 67.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #7 of 10 (permalink) Old 01-21-2008, 09:59 PM
I prefer a 428 with some open chamber heads
but using the parts you have I would go with the 400 and the 670 heads
Jeffs386 is offline
post #8 of 10 (permalink) Old 01-26-2008, 02:12 PM Thread Starter
What kind of compression do you have with 670 heads on a 455? I would like to use pump gas.
post #9 of 10 (permalink) Old 01-27-2008, 11:02 PM
likethat's Avatar
I say 455. I am running a 70 455 H.O. 64 head in my 66 hardtop and a 73 455 with 78 6x heads in my 78 Trans Am SE. both 30 over
likethat is offline
post #10 of 10 (permalink) Old 01-28-2008, 04:38 AM
Showgoat67's Avatar
Send a message via AIM to Showgoat67 Send a message via MSN to Showgoat67
I was running a 1970 455 with 670 heads with a rooler cam for years just switched out the solid roller cam to hyd cam and put eldebrock heads on i like that set up better can actually drive car and not worry about breaking stuff like with that solid cam.
If it isnt a GTO then why are you driving it.[email protected]
Showgoat67 is offline
GTO history 05GTO 2004-2006 GTO General Discussion 9 08-16-2009 05:26 PM
389 vs 400 Marauder 1964-1974 Tempest, Lemans & GTO General Discussion 2 12-11-2004 12:55 AM
400 Or 455? Mike Tenerelli Service, Maintenance and Technical Discussion 2 09-04-2004 10:47 PM
