400 or 455 swap into '66 Lemans - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-14-2009, 08:14 PM Thread Starter
From what I understand, all Pontiac V8's from the 326 to the 455 have the same outer dimensions, but would I have to change anything if I swapped a 400 or 455 into a '66 326 car? Motor mounts, etc? I'd rather have a 389 or 400 but I'm leaning toward a 455 since they're bigger AND cheaper.
The trans is a 2spd, probably an ST300 but could be a Powerglide. I know they worked okay behind a 389, but it's the original trans with 180,000 miles on it and I'd much rather have a 200r4 or TH350.
And finally the rear end is most likely a pegleg, and I want posi. Would a later (68-72) rear end work?
JB_Finesse is offline
post #2 of 5 (permalink) Old 07-14-2009, 08:46 PM
The 455 will go right in. You should use a TH400 trans. The 68 rear is 1 inch wider than the 66, but will fit. You MAY need diffrent coils for the rear swap. Eric
Eric Animal is offline
post #3 of 5 (permalink) Old 07-14-2009, 09:09 PM Thread Starter
Thanks Eric. What would I have to do for the TH400 though, use a '67 GTO console and shifter?
post #4 of 5 (permalink) Old 07-15-2009, 08:39 AM
xcmac26's Avatar
Quoted: 5 Post(s)
TH400 bolts right up to the 400 engine, it's what's in my car. Nothing fancy about it.
xcmac26 is offline
post #5 of 5 (permalink) Old 07-15-2009, 08:41 AM
Quoted: 98 Post(s)
Straight bolt in stuff. You're 2 speed would even work....it's stronger than a TH350 or a 700R4......
69 GTO 455 engine swap pbkgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 04-16-2009 08:34 PM
Valve Cover Opinions Please Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 42 02-19-2009 09:13 PM
71' Lemans motor swap Lemansdude 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 01-20-2009 12:26 PM
400 or 455? rod collins 1964-1974 Tempest, Lemans & GTO General Discussion 9 01-28-2008 04:38 AM
