400 Block ID ? - Pontiac GTO Forum
post #1 of 18 (permalink) Old 11-28-2018, 11:21 PM Thread Starter
Quoted: 5 Post(s)
400 Block ID ?
Just my 1st view of this 1970 242370Pxxxxxx
Car being sold as 1970 400 4 speed ... non matching
Owner said the non matching 400 was a 1970 YD code that has been rebuilt and has many differing parts (heads / intake / exhaust / carb ...)
BUT the Front Block clearly says YS but no other numbers are seen in that area (odd ? though not important)
the Rear Facing Back Passenger side Block is cast is 841988
the Rear Top under the distributor is (see attached) I can't really tell what it says (hard to see and photo)
the Front Right along the side of the timing cover is blank (as far as I could see)
Thats all I got (so far)
I prefer a 1970 Block but not a deal breaker
Can someone read the 2 pix attached under the distributor ? for the year ?
also the passenger side head "front facing" reads SR 834 - I can't find any thing related to that head number ... (no big deal anyway +-)
Thx
C
ID:	116491   Click image for larger version
Cosmic Charlie is offline
post #2 of 18 (permalink) Old 11-29-2018, 09:15 AM
Quoted: 73 Post(s)
I assume you meant to type 481988 for the block casting number. These were used in '71 thru early '75 model cars. Not used in '70.
The date code looks to me to be A041. if this is the case, it was cast Jan 4, 1971. A block with that date code would likely to have been used in a '71 model car.
Looks like a YS code 481988 block could have been used in a '71, '72, '73, or early '75.
Wallace Racing's Pontiac Engine Search
The head ID numbers would be cast with the head, over the center exhaust ports. '71 400 4-barrel heads would probably be #96. But, most any Pontiac heads could have been bolted on, at some point in time.
The 1st pic of a #96 head, shows a date code of L150. So, it was cast in late '70 & used on a '71 400 engine. The 2nd pic is a #96 head with a B191 date code, cast in Feb of '71. It was also used on a '71 model engine. Don't know how many different months these were cast in. But these heads were used only on '71 model year 400 engines.
Name:	#96 L150 .jpg
ID:	116497   Click image for larger version
bigD is online now
post #3 of 18 (permalink) Old 11-29-2018, 10:32 AM Thread Starter
Quoted: 5 Post(s)
the Rear Facing Back Passenger side Block is cast is 841988 = wrong
Yes my typo -
it's 481988 on the block rear and clearly says YS on the front
can anyone decode my low quality picture of the cast block number code from under the distributor ares ?
I can't
C
post #4 of 18 (permalink) Old 11-29-2018, 01:12 PM
Originally Posted by Cosmic Charlie View Post
t
Yes, BigD already responded to you on this, but I'll repeat. Date code is A041 - January=(A) 4=(04), 1971=(1) - that's a model year 1971 block.
post #5 of 18 (permalink) Old 11-29-2018, 01:33 PM Thread Starter
Quoted: 5 Post(s)
Thank You
1971 400 YS code engine
Year Engine HP Engine code Trans CR Cam Head Code BBL Carb No. Misc
1971 400 300 HP YS A 8.2 067 96 1-4 7041264 Block Casting # 481988
Now it has been rebuilt to ... frankenmotor ...
post #6 of 18 (permalink) Old 11-29-2018, 07:00 PM
Quoted: 401 Post(s)
"also the passenger side head "front facing" reads SR 834 - I can't find any thing related to that head number ... (no big deal anyway +-)"
"SR" typically means "Service Replacement." However, this would be found on the front of the block and not the head.
post #7 of 18 (permalink) Old 11-29-2018, 08:12 PM
Quoted: 79 Post(s)
Interested in seeing a photo of the SR stamp along with a zoomed out view to show relative location.
Shake-N-Bake is offline
post #8 of 18 (permalink) Old 11-29-2018, 08:30 PM Thread Starter
Quoted: 5 Post(s)
SR 834 sorry to say I didn't take a picture - it was so clear ...
It was somewhat above the YS stamp, on the right bank head facing the radiator
post #9 of 18 (permalink) Old 11-29-2018, 08:34 PM Thread Starter
Quoted: 5 Post(s)
here is some info from 2 sellers ago
obviously some of it is NOT correct
ID:	116507   Click image for larger version
ID:	116509   Click image for larger version
ID:	116511   Click image for larger version
ID:	116513   Click image for larger version
post #10 of 18 (permalink) Old 11-29-2018, 08:38 PM Thread Starter
Quoted: 5 Post(s)
and this
new 400 pan on old 400 block Cudaboy_71 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 08-09-2017 09:22 PM
block id help cederrowe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-18-2011 12:11 PM
Camshaft ID, Crankshaft ID Help needed. Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 06-01-2010 11:00 PM
Block Code ID Mystery charlie4170 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-16-2010 08:57 AM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 11:55 AM
