400 Block Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-30-2009, 10:33 PM Thread Starter
400 Block Question
Can anyone tell me if there is any difference in the 69 XX2BBL and YS 4BBL Blocks. I know the heads are different but are the bottom ends the same?
Ozzmann is offline
post #2 of 5 (permalink) Old 10-30-2009, 10:44 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Yes and the pistons may be the same too as Pontiac used the combustion chamber to alter the compression ratio.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #3 of 5 (permalink) Old 10-30-2009, 11:16 PM Thread Starter
Thanks Mitch, so a 69 XX Block with a set of 71 66 Heads from a 455, should give you the roughly the same HP as a standard YS 4BBL Factory 400 GTO?
Would that be correct?
Ozzmann is offline
post #4 of 5 (permalink) Old 10-31-2009, 12:10 PM
68greengoat's Avatar
If I'm reading my information correctly, I would say no. A '71 #66 head is chambered at 114cc(low compression), whereas, a '69 head ranges from 56cc - 94cc(higher compression). I guess I would take any '69 head over a #66 head with exception of the 56cc. That was on a 303ci RA V tunnel port(didn't know they made one). The compression would be way too high on a 400. The lowest chamber you'd want to go would be a 72cc head.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 5 (permalink) Old 10-31-2009, 02:41 PM
Quoted: 103 Post(s)
I just sold a set of 66 heads...(1971 455 114cc). I had them on my 400, and they netted me about 7.2 compression. Regular gas, yes, but they were too low of a compression for the 400. The guy I sold them to is putting them on a stroked 455, so they'll be perfect for him. On a 400, with today's gas, you need about an 80--90cc chamber head, or to use slightly dished pistons with the stock high compression 72cc heads. The 2bbl blocks and 4bbl blocks are the same.......only the camshaft and intake were different. Good luck.
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 10:55 AM
Valve Cover Opinions Please Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 42 02-19-2009 09:13 PM
