400 ho - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-05-2010, 08:02 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
400 ho
Always wondered, what makes a 400 HO special from a regular 400?
thanks !!!
Topkat is offline
post #2 of 7 (permalink) Old 11-05-2010, 09:02 AM
Quoted: 118 Post(s)
An 068 cam instead of an 067, and open element air breather, and special high flow exhaust manifolds. Oh yeah, the block code is different, too....WS instead of WT for the stick cars. For automatic cars, YS is the base 400, I forget what the HO auto code is, but it's easily looked up.
post #3 of 7 (permalink) Old 11-05-2010, 09:20 AM
I'm not sure if it's applicable to all years, but I believe HO's had large valve heads. My 69 has #48's which I believe they only put on stick shifts and Ram Air 3's. 428 used the same heads as well as the 350 HO that year. Pontiacs used so many different head castings it's almost insane.
post #4 of 7 (permalink) Old 11-05-2010, 09:27 AM
68greengoat's Avatar
Originally Posted by geeteeohguy View Post
an 068 cam instead of an 067, and open element air breather, and special high flow exhaust manifolds. Oh yeah, the block code is different, too....ws instead of wt for the stick cars. for automatic cars, ys is the base 400, i forget what the ho auto code is, but it's easily looked up.
yz ........
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 7 (permalink) Old 11-05-2010, 09:50 AM
Valves= 2.11 and 1.77.....as i recall
Eric Animal is offline
post #6 of 7 (permalink) Old 11-05-2010, 11:54 AM
Quoted: 118 Post(s)
All standard and HO GTO 400's had the same, big valve heads........#670's. Even some of the early ram air '67's used this head.
post #7 of 7 (permalink) Old 11-05-2010, 06:26 PM
jetstang's Avatar
After 66 all non-2 barrel heads had 2.11/1.77 valves, including the mid 70's 6X heads. I don't know if some of the heads flowed better or what. Round port RAIV heads def flowed better, but that's not the question..
Burning rubber since 1982!!
jetstang is offline
400 Rebuild G-Code72 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 07-30-2009 05:29 PM
$50 or $400? Aramz06 Intake and Exhaust Discussions 14 07-29-2008 07:56 AM
