428 Oil Capacity - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-01-2011, 09:39 PM Thread Starter
Indecision's Avatar
428 Oil Capacity
So I have been trying to find this everywhere, and obviously my GTO books are no good because the engine is probably from a Bonneville. Anybody have this info laying around?
*wait for Bear to chime in with every tolerance for the engine
1966 GTO 428ci/4spd - spun bearing
Indecision is offline
post #2 of 7 (permalink) Old 05-01-2011, 10:50 PM
Ehh... that would be Mr. P --- he's "the man". However, if it's got the stock oil pan then it will be the same as the GTO (and every other REAL Pontiac V8) 5 quarts in the pan plus one in the filter = 6 quarts with oil and filter change.
post #3 of 7 (permalink) Old 05-02-2011, 11:03 AM Thread Starter
Indecision's Avatar
Thanks man, I just wanted to make sure I had enough, but not excessively so. Going to use the Valvoline Racing conventional motor oil, the "not street legal" stuff, not the VR1. I compared it to the Brad Penn and Joe Gibbs stuff and it has the highest ZDPP content, plus it's $1 a quart cheaper. So it's basically full of win.
post #4 of 7 (permalink) Old 05-02-2011, 12:05 PM
Quoted: 103 Post(s)
Depends on the year of the engine/pan. My '65 389 holds 6, my '67 400 holds 7 quarts with filter. Later 400's held less. Your 428 would be 6 or 7.....what does the dipstick say? As long as you're running at least 6, you'll be fine.
post #5 of 7 (permalink) Old 05-02-2011, 12:19 PM
Well whaddya know... turns out I don't know everything (like that's a surprise?)
I didn't know the 67's held more.
post #6 of 7 (permalink) Old 05-02-2011, 01:04 PM
Relax, Rob... Pobody's nerfect...
There were some of the large-journal engines "listed" at 7 qts. 421 comes to mind. The best bet is what's already been suggested. Put in 6 and see where the stick "shows".
Unless you plan to change the oil after every or every "other" outing, DO NOT use "racing" oil. While race oils have higher lubricity, they don't have the stabilizing and anti-acid additives "street" oil has. "Short life". If a flat-tappet cam., we use Shell Rotella 15W-40.
FWIW
Jim
Mr. P-Body is offline
post #7 of 7 (permalink) Old 05-03-2011, 12:22 PM Thread Starter
Indecision's Avatar
Good to know, thanks for the info!
LS2 oil capacity... Poncho Dan Engine Discussions 13 04-25-2010 09:14 AM
Oil type and capacity Jstreet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 49 10-29-2009 10:52 PM
67 GTO A/C Oil Capacity / R134A Conversion brock5ga 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-05-2009 08:44 PM
Oil capacity difference for 2004 and 05-06. alandgre 2004-2006 GTO General Discussion 2 08-29-2008 10:35 AM
428 Oil Dipstick asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-11-2008 08:04 PM
