428 oil pressure - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-28-2013, 12:20 PM Thread Starter
Griff's Avatar
428 oil pressure
I have had a '66 GTO with a '67 428 engine for the last three years. It's a dream to drive. Only bummer is that the driving season is so short up here. I finally decided I was tired of idiot lights and installed a three guage cluster (oil, temp, and volts) under the dash. Now it has dawned on me that I'm not sure what the oil pressure should be. Thanks.
Griff is offline
post #2 of 3 (permalink) Old 07-28-2013, 12:25 PM
What's it showing now? To be valid, you should make sure the motor's completely warmed up, and has been warmed up for at least 10-15 minutes (takes longer to get the oil warm than it does the coolant).
Oil pressure is going to be lower at idle than it is at 2000 rpm up. It's also going to vary depending on the viscosity of the oil you're using. As long as you've got, oh say 15-20 or so at idle and 40-60 at rpm, you ought to be ok.
post #3 of 3 (permalink) Old 07-28-2013, 12:59 PM Thread Starter
Griff's Avatar
Thanks Bear. It shows 20 at idle and 50 cruising.
Griff is offline
Oil Pressure Metallifan Engine Discussions 3 08-05-2013 06:57 PM
Low oil pressure/oil light coming on etewald 1964-1974 Tempest, Lemans & GTO General Discussion 8 01-26-2013 08:16 PM
428 Oil Capacity Indecision 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2011 12:22 PM
no oil pressure wingnutooa 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 02-14-2009 01:52 PM
428 Oil Dipstick asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-11-2008 08:04 PM
