455 Question - Pontiac GTO Forum
post #1 of 13 (permalink) Old 04-08-2011, 06:56 PM Thread Starter
Josh.AZ.GTO's Avatar
455 Question
If the engine was originally set up from factory as an automatic.....will it directly bolt up to a muncie 4 spd? My car was originally a 4spd and was converted over to an automatic. I want to change it back, and found a year matching 455 block for sale that was from an automatic car.
I've always assumed they could easily accept either or..but I'm not sure and that is why I'm asking.
Thank you in advance.
JR
JOSHUA
1970 GTO 455HO Cardinal Red
Josh.AZ.GTO is offline
post #2 of 13 (permalink) Old 04-08-2011, 07:09 PM
JR
The bolt pattern on the rear of the engine is the same, so no worries there. I've heard, but never personally verified, that occasionally you might find a block from an automatic car that doesn't have the driver's side "socket" for the clutch Z-bar drilled, and also - on occasion - you might find a crank that isn't drilled to accept the transmission pilot bushing. Both of those are at least worth checking before you plunk down your cash.
post #3 of 13 (permalink) Old 04-08-2011, 07:15 PM
I've heard the same about the crank/pilot bushing, never seen one though......I personally would run a hydraulic clutch, you won't need the "clutch linkage" then... E
Eric Animal is offline
post #4 of 13 (permalink) Old 04-08-2011, 08:18 PM Thread Starter
The block is a code XF and block only. If this helps for any more information.
JOSHUA
post #5 of 13 (permalink) Old 04-08-2011, 10:01 PM
Gotta start with the date code first - that's 4 characters near the distributor hole, on top of the rear of the block. Until you know what year it is, that XF doesn't tell you much.
post #6 of 13 (permalink) Old 04-08-2011, 10:08 PM Thread Starter
XF 0258327.
Does this help Bear?
JOSHUA
post #7 of 13 (permalink) Old 04-08-2011, 10:19 PM
XF 0258327.
No sir, that's a sequence number used during engine manufacture - doesn't really relate to anything.
Go here: How to identify your Pontiac engine
It has an example of where to find the date code and also shows you how to decode other things.
post #8 of 13 (permalink) Old 04-08-2011, 10:47 PM Thread Starter
It appears to be K139 (November 13th, 1969)
JOSHUA
post #9 of 13 (permalink) Old 04-08-2011, 11:11 PM
Well all-righty then. It's probably model year 1970 and therefore a 370 horse 455 out of a Grand Prix, but I 'spose also could be very late 69 and a 428 (both used XF). Go back to the same web site, see if you can get the 7-digit block casting number off the top rear passenger side - that'll clinch it. Also if it's a 455 you should find "455" cast into the side above the oil pan rail.
Next assignment is to ID the heads. You should be able to find antoher 4-character date code on the sides, similar format to the date code on the block. Then get the two (sometimes 3) character code from the tops of the center two exhaust ports.
post #10 of 13 (permalink) Old 04-08-2011, 11:26 PM Thread Starter
Unfortunately the motor is a block only with no heads. The guy who has it did say it was from a Grand Prix though. That being said I have a Pontiac 350 (1970) carb to pan. I plan on reusing the Q-Jet. Were the heads mostly interchangeable?
JOSHUA
455 question? tyler t 1964-1974 Tempest, Lemans & GTO General Discussion 55 12-13-2017 02:14 PM
Chevey 455 Engine Question RKLamb The Lounge 20 03-10-2011 02:07 PM
455 engine question Cpldavis37 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 02-04-2010 09:24 AM
motor/carb question for 65 gto/70-455 rbpwrd240 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 11-12-2008 08:36 AM
Exhaust question for a 1973 455 cmunson 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-21-2008 10:21 AM
