64 GTO battery cable melt down - Pontiac GTO Forum
Rlamarche1
post #1 of 5 (permalink) Old 06-05-2017, 03:45 PM Thread Starter
Rlamarche1's Avatar
Quoted: 11 Post(s)
I posted a thread the other day concerning this and got good advice on troubleshooting. The positive cable to the starter shorted on the exhaust manifold. I cut off the bad section and put a new terminal end on and reinstalled the starter. I checked continuity from the starter to the terminal block on the fender. Checked good. I also checked for continuity from the positive cable on the starter to the ground stud on the block. I had continuity there when I shouldn't have. Could I have fried the starter?
Rlamarche1 is offline
post #2 of 5 (permalink) Old 06-06-2017, 07:38 AM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
I could be wrong, but I think you are supposed to have continuity.
Seeing it typed out, I'm thinking "how can that be?" So... IDK
64GTOConvertible is offline
post #3 of 5 (permalink) Old 06-06-2017, 09:31 AM Thread Starter
Rlamarche1's Avatar
Quoted: 11 Post(s)
I have continuity from the positive terminal on the starter solenoid with the cable connected to the terminal block on the fender well, which is where the positive cable from the battery goes to. I also have continuity from the same terminal on the starter solenoid to the ground stud on the block, which is where the negative cable from the battery goes to. That would be a dead short I would think. I'm I possibly fried the starter solenoid, but I don't want to buy just the solenoid if it could be the starter. Any thoughts?
post #4 of 5 (permalink) Old 06-06-2017, 02:21 PM
Quoted: 17 Post(s)
Yeah, that's not right. I read "checked continuity from the starter to ground". And BTW, you should have continuity there. The solenoid energizes the positive side of the starter when it's engaged. The + side of the solenoid should NOT have continuity to ground unless it is engaged.
In other words, I think your solenoid is fried!
post #5 of 5 (permalink) Old 06-06-2017, 04:02 PM Thread Starter
Rlamarche1's Avatar
Quoted: 11 Post(s)
I bought one at Auto Zone today. Going to install it tomorrow. I'll let you know the results.
Battery cable color alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-18-2016 08:16 PM
67 GTO Positive Battery Cable Routing Kev0477 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-30-2014 02:07 PM
New Battery Cable Oldeboy 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-23-2013 10:15 AM
battery cable tube Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 9 07-07-2011 04:14 PM
Battery Cable Ground injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-02-2010 08:54 AM
