64 GTO electrical problem - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-08-2017, 02:14 PM Thread Starter
Rlamarche1's Avatar
Quoted: 11 Post(s)
Last week the positive battery cable to the starter solenoid shorted out on the exhaust manifold causing both battery cables to melt. I fixed the cable to the solenoid and replaced the battery cables. When I turn the ignition to start, I am getting power to the yellow wire that goes to the "R" terminal on the solenoid but nothing happens. I tried replacing the solenoid. Same thing. How can I track the source of this problem down? I pulled the starter and did a bench test. It worked fine when taking a screwdriver between positive and the "S" terminal, but did nothing when going from positive to the "R" terminal. I don't think this is the original wiring harness. The wire going to the solenoid was yellow. What will happen if I run that yellow wire to the "S" terminal?
Rlamarche1 is offline
post #2 of 3 (permalink) Old 06-08-2017, 05:56 PM
Quoted: 391 Post(s)
The wire goes on the "S" terminal.
post #3 of 3 (permalink) Old 06-10-2017, 05:39 PM
Quoted: 118 Post(s)
The R terminal is not used in these cars. The wire goes to the S terminal, as Jim stated.
68 GTO A/C Heater electrical problem Mark 68 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-28-2013 10:40 PM
2004 GTO Electrical Problem With Wipers & A/C Panel Lights, Radio 1LS1 2004-2006 GTO General Discussion 0 07-27-2011 12:41 AM
2004 GTO Electrical Problem With Wipers & A/C Panel Lights, Radio 1LS1 Interior Discussions 0 07-27-2011 12:35 AM
69 GTO electrical problem Luiz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-07-2009 10:35 PM
Help on a 71 GTO, Electrical problem Rezombie 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-24-2009 12:46 PM
