65 GTO Build - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-25-2018, 04:59 PM Thread Starter
renorealtors's Avatar
Quoted: 13 Post(s)
65 GTO Build
Update 12/25/18 Just got the motor back from the machine shop after dyno work. Does anyone have a PDF or link for a 1965 GTO wiring harness?? Also a pic of a Street Tracker I just finished.
Thought I would start a new thread for the build. I have to say Herbert Machine Shop in Reno was a pleasure to work with and I am jazzed with the work!
Buttler was just as helpful and not one thing needed to be returned. Wish I could say the same for Hotchkis!
ID:	116939   Click image for larger version
ID:	116941   Click image for larger version
ID:	116943   Click image for larger version
ID:	116945   Click image for larger version
renorealtors is offline
post #2 of 8 (permalink) Old 12-25-2018, 08:57 PM
Quoted: 401 Post(s)
Nice number. About what I hope to get out of my 455 build, but using iron heads. What cam and specs?
Ditch the steel fan. Get either a clutch fan set-up or flex fan.
Get the wiring harness diagram that most recommend. It is color coded and laminated. You can get a factory diagram which should be in the 1965 Service Manual, but several say the color coded and laminated one is far better. https://www.classiccarwiring.com/tempest/
Last edited by PontiacJim; 12-26-2018 at 06:11 PM. Reason: Corrected link to wiring diagrams
post #3 of 8 (permalink) Old 12-26-2018, 12:46 AM
Quoted: 31 Post(s)
Get the wiring harness diagram that most recommend. It is color coded and laminated. You can get a factory diagram which should be in the 1965 Service Manual, but several say the color coded and laminated one is far better. https://www.classiccarwiring.com/196...iring-diagram/ [IMG class=inlineimg]https://www.gtoforum.com/images/smilies/thumbsup.gif[/IMG]
Am I missing something? Hard to tell anything from that DYNO sheet without rpm . They look like great number but need to see where they are with rpm. Street or strip motor ? Happy holidays . Doug
dd68gto is offline
post #4 of 8 (permalink) Old 12-26-2018, 09:19 AM
the65gto's Avatar
Quoted: 12 Post(s)
Great looking engine. Assume 389?? Nothing that great under my xmas tree :-(
the65gto is offline
post #5 of 8 (permalink) Old 12-28-2018, 10:25 AM Thread Starter
Quoted: 13 Post(s)
Once again THANK YOU for the lead on wiring! I just cleaned and painted the fan and was wondering what to do about cooling? It was recommended to try the oem radiator and see but I am in cruise lines here in Reno with Hot August Nights and don't want to worry. Any perfect set up for the stroker?? Below is a new pic showing the RPM,I cut it off on the other pic. Happy New Year Jim and Doug
post #6 of 8 (permalink) Old 12-28-2018, 10:44 AM Thread Starter
Quoted: 13 Post(s)
Oh yes the motor is the original 389 and I will use it on the street. The transmission is a nearly new one I found at my trany shop. It has the Auto Gear case among other things in it. I sent the steering box out for quick steer upgrade, looks great. Went round and round with PS pumps and finally just cleaned up the old one and will see if it works? Summit is in Reno\Sparks and i took 3 home and none of them would mount up!
ID:	117011   Click image for larger version
ID:	117013   Click image for larger version
ID:	117015   Click image for larger version
ID:	117017   Click image for larger version
post #7 of 8 (permalink) Old 12-28-2018, 10:46 AM Thread Starter
Quoted: 13 Post(s)
One last thing? How can I get an email or notification to let me know you guys are posting on the thread?
ID:	117021   Click image for larger version
ID:	117023   Click image for larger version
ID:	117025   Click image for larger version
ID:	117027   Click image for larger version
post #8 of 8 (permalink) Old 12-28-2018, 10:58 AM Thread Starter
Quoted: 13 Post(s)
Here is some more info from the motor. Cal Cams was from butler.
ID:	117031   Click image for larger version
ID:	117033   Click image for larger version
ID:	117035   Click image for larger version
to build or not to build (4L60E) rednblackgoat Service, Maintenance and Technical Discussion 1 05-28-2017 10:33 AM
'65 Tempest wagon budget build Goatnut 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 22 09-06-2016 10:17 PM
65 GTO (clone) build Dunnburger 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 49 06-03-2012 04:15 PM
65 GTO Audio Installation Build Log NeverEnuffBass 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 27 04-25-2012 05:29 PM
Considering a GTO...build quality issues? squirrels 2004-2006 GTO General Discussion 22 07-06-2006 10:16 PM
