65 GTO carbon center caps how to - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-16-2014, 04:05 PM Thread Starter
crustysack's Avatar
Well i got the new wheels and the center caps were hideous so i decided to make cf ones, someone asked for pics on how to do it so heres the steps to make the mold.
pic 1 design something and draw it out full scale
2- be handy with rhino or other 3d modeling program(or have an engineering friend)to draw file and then have them write cnc cut program
3- buy $500k 5 axis cnc machine and throw a block of mdf or suitable male molding material
4- have operator cut mold on cnc
5-finished male mold ready for next steps
ID:	41993   Click image for larger version
ID:	42001   Click image for larger version
ID:	42009   Click image for larger version
ID:	42017   Click image for larger version
crustysack is offline
post #2 of 8 (permalink) Old 07-16-2014, 04:11 PM Thread Starter
crustysack's Avatar
this is a male plug to make a female carbon mold so the next steps are
1-cover in release film, this is a self adhesive teflon, teflon needs to be wall paper cut so there are no overlaps since those will transfer
2 center piece done
3 cover flat surface
4 teflon is then vacuum bagged to surface to remove any air bubbles
ID:	42033   Click image for larger version
ID:	42041   Click image for larger version
ID:	42049   Click image for larger version
post #3 of 8 (permalink) Old 07-16-2014, 04:11 PM
Couldn't you make a reverse mold out of the original caps? Or no?
post #4 of 8 (permalink) Old 07-16-2014, 04:21 PM Thread Starter
crustysack's Avatar
plug is now ready to layup on
1 material all ready to go, carbon,peelply,perf and breather and vacuum bag and plastic on table to pour resin- can get messy-
2 resin and hardener are weighed out- mix ratios are critical- this is a high tg resin that will not distort at temps up to 115 degrees celsius
3 thicken up a small batch of the epoxy to fill the finer details in the plug
4 skim the plug with the thickened epoxy to get all details
5 wet out the carbon with the non thickened epoxy
ID:	42065   Click image for larger version
ID:	42073   Click image for larger version
ID:	42081   Click image for larger version
ID:	42089   Click image for larger version
post #5 of 8 (permalink) Old 07-16-2014, 04:29 PM Thread Starter
crustysack's Avatar
next apply the wet out layers of carbon to the mold- the laminate should be balanced in weight and fiber direction so the laminate schedule is:
1 rc200 (twill)
1 xc411 (double bias)
2 rc200
1 xc411
2 rc200
1 xx411
1 rc200
this ensures the mold itself will not warp or curve or do anything funky
1-apply layers smooth down with hand to get material to take shape of plug
2 after all layers are down put peel ply on
3 apply perf and breather material - this allows air and extra resin to be sucked out
4 stick in vac bag
5 turn vac on
ID:	42105   Click image for larger version
ID:	42113   Click image for larger version
ID:	42121   Click image for larger version
ID:	42129   Click image for larger version
post #6 of 8 (permalink) Old 07-16-2014, 04:33 PM Thread Starter
crustysack's Avatar
vac bag will suck out excess resin and more importantly air in the laminate
series of shots over about 5 minutes to show resin consolidation. vacuum pump runs at 1 atmosphere which is approx 15 psi
ID:	42185   Click image for larger version
ID:	42193   Click image for larger version
ID:	42201   Click image for larger version
ID:	42209   Click image for larger version
post #7 of 8 (permalink) Old 07-16-2014, 04:42 PM Thread Starter
crustysack's Avatar
allow to dry overnight then resin is post cured at 60c for 4 hours then 100c for 4 more hrs under vacuum
1 mold is done
2 popped off plug
after a coating with mold release this mold will be ready for pre preg lamination, heat stable and production ready.
NOW i can start to make the pieces
ID:	42225   Click image for larger version
ID:	42233   Click image for larger version
ID:	42241   Click image for larger version
ID:	42249   Click image for larger version
post #8 of 8 (permalink) Old 07-16-2014, 04:43 PM Thread Starter
crustysack's Avatar
yes i could have - but they were ugly so i designed my own
Center Caps shelbee350 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 10-31-2012 09:22 AM
1970 gto 455ho rally ii wheel center caps ramosmar 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 10-04-2012 04:36 PM
65 GTO carbon fiber center console crustysack 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 13 04-22-2010 07:30 PM
which are the right center caps?? 69billygoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-07-2009 09:40 PM
center caps... QuikLilGoat Wheels and tires 1 12-17-2008 10:53 AM
