65 gto turn signal/tilt wheel problem - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-09-2009, 05:39 PM Thread Starter
Hi guys,
Ive got a issue w/ my turn signals on my mostly stock 65 gto 4 spd tri pwr,maybe some of you have run into this before-I'm ready to pull my hair out...
Right hand turn signals seem to operate normally as does parking/brake lights.Ive checked and cleaned all grounds,checked for power/ground at LR light harness,still turn signals,brake lights and running lights work intermintantly at LR.
While in the middle of trying to diagnose the LR light issue,I notice that when I'm pressing the brake pedal my dash lights come on and off when pedal is raised and lowered.I then realize theres a tilt column switch at the base of the column under the dash,it is cable driven[it slides back and forth as the column is raised up and down]and I believe according to the wiring diagram my brake/turn signals/running lights run thru that switch.
So then I realize as I'm raising and lowering the tilt wheel,my dash lights are going on and off by themselves.I removed that switch and the housing came apart and little balls/springs and brass parts all fell out.
I found the new switch online for 68 bucks,but before I start "throwing parts" at the problem,I thought I'd get your opinions.
thanks for your help....
jalopy junkie is offline
post #2 of 2 (permalink) Old 06-09-2009, 07:38 PM
Sounds to me like the part with the little balls, springs and brass things were contacts that were loose ......I would change that part, as it definately is shot now....
Eric Animal is offline
Potentially serious GTO problem - everyone inside! Yankee Drive train, suspension, alignment and brakes. 67 04-22-2007 07:10 PM
GTO with an LSD problem?? twolf Service, Maintenance and Technical Discussion 3 03-28-2005 11:19 AM
UK's Top Gear reviews the GTO. 1COOLPC 2004-2006 GTO General Discussion 4 08-10-2004 06:18 PM
2005 GTO information Troy Roberts 2004-2006 GTO General Discussion 9 08-05-2004 01:38 PM
