65 headliner braceing - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-22-2017, 09:02 PM Thread Starter
CPL
Quoted: 14 Post(s)
My 65 headliner was pulled out when I bought it.I will be installing a new headliner.my issue is it looks as if the front to rear,and side to side braceing rails have been pulled down.My question is dose the top brace rail going from front to back supost to be Laing against the ceiling top and is the side to side rail supost to be connected to the top rail?my front to back rail is about 1/4 inch from ceiling my side to side rail is about 1/4 inch away from top rail.any help will be appreciated...and if anyone has pictures of the way they are supost to be they would be a big help
Thanks for your time
CPL is offline
post #2 of 5 (permalink) Old 03-23-2017, 05:53 PM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
That all sounds about right.
The support bracing isn't right against the roof panel,
in fact you may find/see dabs of panel bonding in spots.
If you want to gauge the radius just install the headliner bows and this will show you if any are possibly low.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 5 (permalink) Old 03-25-2017, 03:44 PM Thread Starter
CPL
Quoted: 14 Post(s)
OK is there a pad or anything between the lower and upper rails?
CPL is offline
post #4 of 5 (permalink) Old 03-26-2017, 05:02 AM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
Originally they used the glued on fibrous insulating padding similar if not the same as the stuff under top of dash.
The stuff that disintegrates into powder if sneezed on
Scrape all that crap off, clean the underside and use a good peel & stick type product for sound/heat.
post #5 of 5 (permalink) Old 03-26-2017, 09:00 AM Thread Starter
CPL
Quoted: 14 Post(s)
If my rails are pulled down is there a way to get them back to where they go?
CPL is offline
Headliner nightmare OrbitOrange 1964-1974 Tempest, Lemans & GTO General Discussion 11 06-27-2017 09:02 AM
68 or 68 headliner? Molten 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 01-17-2016 03:16 AM
06 Headliner MikeT 2004-2006 GTO General Discussion 0 08-19-2015 08:34 AM
Headliner johnfin 2004-2006 GTO General Discussion 2 10-23-2014 10:15 AM
Headliner blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 06-16-2008 02:10 PM
