65 hood insert question - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-13-2014, 10:15 AM Thread Starter
old-goat's Avatar
Does the hood scoop insert on the '65 have any kind of sealant or gasket under it? I can't find anything from PY or Ames. I'm thinking of just applying some seam sealant or something under it.
old-goat is offline
post #2 of 6 (permalink) Old 03-13-2014, 12:12 PM
Quoted: 117 Post(s)
No, nothing under the scoop. Metal to metal contact. No need for a gasket or sealer.
post #3 of 6 (permalink) Old 03-13-2014, 03:07 PM Thread Starter
old-goat's Avatar
Kinda what I thought, mine will let a little water leak through onto the carbs so that's why I asked. I don't think I want to put seam seal or silicone under it in case I need to remove it later - I don't want it stuck down too hard
old-goat is offline
post #4 of 6 (permalink) Old 03-13-2014, 05:40 PM
rickm's Avatar
Quoted: 5 Post(s)
they do sometimes leak. if you look on page 83 of the gto restoration book, you will see some type of gasket in the illustration.
rickm is offline
post #5 of 6 (permalink) Old 03-14-2014, 12:18 PM
Quoted: 117 Post(s)
I've owned and scavenged a bunch of '65-'67 GTO's, and none ever had a gasket. If you want to seal it, I would use AC dum dum or strip caulking. It's dry, easy to stick in place, will flatten when you squeeze it, but will peel right off and not leave a mess.
post #6 of 6 (permalink) Old 03-14-2014, 03:13 PM Thread Starter
old-goat's Avatar
Thanks, that sounds like a good idea, I doubt I would ever have to remove it again, but who knows?
old-goat is offline
1966 Hood insert modification Bensjammin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 04-17-2013 09:45 AM
Hood Scoop Grill Insert BrienCharles 2004-2006 GTO General Discussion 4 03-27-2008 10:00 AM
