'66 389 heads for California A.I.R. pump - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-25-2017, 09:25 PM Thread Starter
Hello all!
I'd like to know if any '66 GTO head can be made an A.I.R. head just by unplugging the end caps, and how easy is that on a very old, long-time plugged head? Or if it's worth doing even? I have incorrect heads on it now, and it is the original AIR setup (no A/C) which dictates a timing change but obviously does little for emissions, per the CO warnings and no cat converter. I am sure running the AIR pump with plugs in the heads would kill it fast, and I kind of want to keep it stock. 389, Carter AFB w/4 spd. Any thoughts out there?
jandyk is offline
post #2 of 2 (permalink) Old 08-28-2017, 09:14 AM
The end caps are basically a freeze plug, your machinist can quickly remove each plug, or you can do so, exposing the AIR galley.
65 GTO 389 Water Pump Plates? Roqetman 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 9 04-02-2017 04:02 PM
Heads on 389 help Billoney 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 04-04-2013 09:08 AM
Installing Mechanical Fuel Pump on '65 389 deerhaven 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-31-2012 10:35 PM
Best aftermarket 389 (8 bolt) water pump? goatcheese 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 09-13-2012 10:45 AM
