66 GTO 389 Tri - "Screeching" noise when car first starts - Pontiac GTO Forum
post #1 of 10 (permalink) Old 07-18-2014, 08:22 AM Thread Starter
jgotzens's Avatar
As soon as I turn the key there is a loud short skreeching sound and the car fires right up. Usually it's a sign of maybe a loose belt, but they all seem tight. The sound doesn't continue while the car is running so I don't think it's a pully.... any suggestions.
jgotzens is offline
post #2 of 10 (permalink) Old 07-18-2014, 09:28 AM
Starter shimmed correctly? Check the flywheel teeth and the teeth on the starter bendix for wear.
Also check belt alignment, Pontiacs used so many different pulley configurations and bracket spacers that it is not uncommon to have some vertical alignment issues. Take a long straight edge if you can and hold it flat against the face of the pulleys that share a belt to make sure they are aligned. The straight edge should sit perfectly flat on the face of both pulleys. Belts should all appear straight when viewed from the side.
post #3 of 10 (permalink) Old 07-18-2014, 11:37 AM
Does it screech before the car starts or right after it starts?
post #4 of 10 (permalink) Old 07-18-2014, 12:30 PM Thread Starter
jgotzens's Avatar
The minute I turn the key it does it. It doesn't sound mechanical, like metal on metal. Sounds like my 70 Chevelle used to when the belt got worn or the tensioner went bad. But like I said they feel really snug.
jgotzens is offline
post #5 of 10 (permalink) Old 07-18-2014, 01:02 PM
Pull the coil wire off so it doesn't start and just crank it and see if it happens.
post #6 of 10 (permalink) Old 07-25-2014, 01:48 PM Thread Starter
jgotzens's Avatar
Took off the coul wire and it cranked, but no screeching noise.
jgotzens is offline
post #7 of 10 (permalink) Old 07-25-2014, 01:50 PM
Okay then I would put the coil wire back on and take off the belts and try it again.
post #8 of 10 (permalink) Old 08-07-2014, 01:35 PM Thread Starter
jgotzens's Avatar
Well I finally foundf out what this noise was. The person who had the car before me added a high output Be Cool radiator and added a OE fan shroud. Since they don't come to fit the Be Cool it had to be modified. I say that loosely since it came loose and a chunk broke off. When I took a good look at the broken piece and what was still attached to the radiator I could see where the fan blades were rubbing on the shroud on the bottom. It seems that little bit of engine torque when you start the car was enough to make contact witht he shroud. with the whole thing off the noise is gone.
jgotzens is offline
post #9 of 10 (permalink) Old 08-07-2014, 02:06 PM
Awesome that you found it, but you should run a shroud. I would trim t were the fan was hitting it and put it back on.
post #10 of 10 (permalink) Old 08-08-2014, 01:06 PM Thread Starter
jgotzens's Avatar
Yea, plan on it. The top third of it broke off, so three quarters of it is still in place. I ordered another OE one and plan to trim it to size ( the right way ) It's hard for me to figure how a supposed "car guy" (the previous owner) lucky enough to have a car like this can "half ass" the modifications/repairs. Oh well, she's in good hands now ! Thanks for your input here.
jgotzens is offline
Looking for help wih a "modern" 389 build sr71 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-20-2012 09:26 AM
Looking for help wih a "modern" 389 build sr71 Engine Discussions 2 06-17-2012 12:58 AM
"Resonance" Rice Noise?!? HELP! cardgrl Intake and Exhaust Discussions 10 05-04-2012 12:28 PM
Steering "clunk" noise SJAndrew 2004-2006 GTO General Discussion 0 06-22-2005 09:32 PM
1966 389 "xs" motor gto-pete 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 12-09-2004 07:25 PM
