66 gto identification help - Pontiac GTO Forum
post #1 of 9 (permalink) Old 09-08-2015, 06:51 AM Thread Starter
I guys, new to the forum but a 68 chevelle owner that I have finished restoring.
I'm currently looking to swap my beloved chevelle for what is supposed to be a matching numbers 66 GTO. Having trouble attaching pics via iPad so I'll detail what I have so far.
VIN 242176Z121111
Engine casting number D 9778789
Stamped near the head on passenger side of engine 468559 with the letters WV underneath.
Transmission is a Muncie with a stamp 3925660 And a tag 3687268 attached.
Also has tri power with Rochesters.
Help please
Rob
1966OZGTO is offline
post #2 of 9 (permalink) Old 09-08-2015, 03:05 PM
alanmay0's Avatar
numbers on 66 GTO
Hello I can help you with some of the numbers because I just purchased a 67 GTO and researched the numbers on the data plate, which is what your picture is of.
The 242= GTO
the 17=hard top
the 6= year model
the 2= made in Calif
the 121111 is a production number
the WV on the engine = 360 HP manual transmission (to have the 360 HP you should have the tri-power
That's all I know. hope it helps some
alanmay0 is offline
post #3 of 9 (permalink) Old 09-08-2015, 03:25 PM
Quoted: 106 Post(s)
The 242= GTO
Actually the 2 is the division=Pontiac and the 42=GTO.
The best way to make sure of the cars pedigree is to order a PHS report.
PHS Historic Services
The 2=Division Pontiac
The 42= GTO
the 17=hard top
the 6= year model
the Z= made at the Fremont plant in Ca.
the 121111 is a production number.
Goat Roper is offline
post #4 of 9 (permalink) Old 09-08-2015, 05:52 PM Thread Starter
Ok sounds right so far and I will order a report as mentioned.
There is one strange thing that's troubling me a little though. Is it possible or has anyone seen the front indicator lights in the bumper on a 66 rather than on the grille. GTO badge is on the right side of the grille and the front grilles look to be 66 not 65.
Could that be early factory install or the bumper swapped for a 65 (don't know if they were interchangeable?
See pic of car attached.
post #5 of 9 (permalink) Old 09-08-2015, 06:27 PM
Quoted: 106 Post(s)
Possibly a replacement bumper off of a '66 Tempest.
Looks like it isn't hung right either.
post #6 of 9 (permalink) Old 09-08-2015, 08:17 PM
I would check for rosette rivets on the vin tag and verify the data plate is also from California. Any pictures of the above items?
05GTO is offline
post #7 of 9 (permalink) Old 09-08-2015, 10:49 PM Thread Starter
Here is a pic of the vin tag, it doesn't look like it's been tampered with. Cowl tag attached in previous post. I punched that into the decoder on this site and it came up California built.
post #8 of 9 (permalink) Old 09-09-2015, 05:30 PM
Quoted: 118 Post(s)
The pic shows a LeMans grille and front bumper, not GTO stuff. This calls for inspection of the inner front fenders for evidence of LeMans badging holes filled in. My bet is that this car has been in a front end collision, and has a LeMans front clip. Not uncommon. You need to figure the price of a correct GTO grille in with the car. The bumper is the same....just remove the lights.
post #9 of 9 (permalink) Old 09-09-2015, 05:55 PM Thread Starter
Ok, if that's all it is then should be a go on the purchase as all other numbers etc check out as genuine GTO.
Sound right to you guys?
Basically I'm swapping a restored 68 Malibu (not matching engine number) for this GTO and also getting 5k cash on top. Hadn't factored a grille but plenty of repro options.
Also looked through the trunk and found a set of lights that must be for the "correct" grill last night.
Had GTO up on the hoist. No rust or major mechanical issues but will need new exhaust and interior re apohoster and a bit of TLC, dash fascia, knobs etc.
What are you seeing these go for in the states? Considering Aussie dollar is crap vs USD at the moment. Ie 1 Aussie dollar equal to say 63 cents USD.
Pic of chevelle attached for interest only. I have about 28k Aussie dollars into the Chevelle.
Really appreciate the advise from you guys on this and Keen to get the real deal!!
Rob
GTO Head Identification 68SOFGOAT 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-17-2015 11:49 PM
Engine Identification 70 GTO goatship 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 03-14-2012 12:20 PM
69 GTO engine identification help......... Eshack80 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 12-14-2010 04:08 PM
70 GTO diff Identification Stubacca 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 06-10-2010 05:08 AM
GTO Radio Identification GTOBOB 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 02-18-2007 04:03 PM
