66 tri-power jetting - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-25-2015, 03:43 PM Thread Starter
I am taking my #s matching motor out of my 66 so I don't hurt it and building a 400 4.25 stroke 6x heads and want to keep my tri power can anyone give me some help on jetting size this is 66 tripowerwhen done cid: 460
mikey9743 is offline
post #2 of 2 (permalink) Old 10-26-2015, 12:12 PM
Quoted: 117 Post(s)
Lots of info on the web if you search. You also need to consider today's alcohol laced fuels, which requires slightly more fuel. Most likely, you would need to go up about 2 jet sizes. A lot also depends on your cam and exhaust, as well. An o2 sensor and or a dyno would be a huge help, as opposed to the old-school seat-of-the-pants, read the spark plugs method. I would start with the stock jets, which may work just fine, and go from there.
tri power krallstar 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-23-2015 08:14 PM
Tri Power 65gto 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-29-2013 03:11 PM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
65 tri-power orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-22-2012 08:20 AM
65 tri power jetting SIXT5GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-10-2011 12:55 PM
