67 335 Horse air cleaner - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-22-2014, 09:01 AM Thread Starter
doowopdave's Avatar
This might be a dumb question, but I'll ask it anyway: has anyone figured out a way to adapt the short, louvered 67 air cleaner to a Holley carb? I like the look of my car's original, but I'm much happier with my Hollley 3310 750 cfm carb than the Q-jet. I have been unable to figure out a way to make the air cleaner fit the top of the Holley's body.confused
doowopdave is offline
post #2 of 3 (permalink) Old 02-23-2014, 06:27 PM
gtoguy389's Avatar
Is the air horn ring where the air filter base mounts larger on the Holley than the Quadrajet, or smaller? If it is smaller, you might be able to try the air filter base from a '66. The only difference between the '66 and '67 pancake air filters was the opening in the base as the '66 Carter AFB was a smaller opening than the Quadrajet. If memory serves me right, the AFB opening was 4" and the Quadrejet opening was 5".
gtoguy389 is offline
post #3 of 3 (permalink) Old 02-23-2014, 08:59 PM
SCG Pontiac's Avatar
it should be pretty easy to fabricate a connection to your stock low profile vented breather. A strip of thin aluminum, rivet gun and some silicone to seal the riveted piece should do the trick.
SCG Pontiac is offline
air cleaner Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 10 10-30-2011 07:01 AM
Horse Power Ratings for 1967 GTO "Standard" 335 HP 400 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-28-2011 07:28 AM
air cleaner and A.I.R. Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 02-19-2011 05:39 PM
Can anyone ID this air cleaner? Edelbroke 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-05-2010 10:18 PM
Air Cleaner ID Frank Rossi 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-23-2009 09:06 AM
