67 Chevelle Rearend in a 68 Lemans? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-27-2014, 04:44 PM Thread Starter
Hey All,
I have a 68 Lemans with a 2 speed and a 2.73 rear end. I am having the motor rebuilt and would like to up the rear end gearing a bit. I came across a guy selling a fully rebuilt axle from a 67 Chevelle with a 3.08 gear. Any idea if this axle would fit my 68. If so, any modifications needed? Thanks a lot for the help!
Chicago Nick is offline
post #2 of 6 (permalink) Old 10-27-2014, 06:13 PM
Quoted: 23 Post(s)
It will bolt right in, only difference is it will be 1/2" narrower than yours. Is it a 12 bolt, or GM 10 bolt?
Instg8ter is online now
post #3 of 6 (permalink) Old 10-27-2014, 06:22 PM Thread Starter
Thanks for the info. Its a 10 bolt. Will that half inch require any mods?
post #4 of 6 (permalink) Old 10-27-2014, 06:28 PM
Quoted: 23 Post(s)
wider tires...
post #5 of 6 (permalink) Old 10-27-2014, 06:31 PM Thread Starter
Ahh, you mean half in narrower overall width. I have plenty of rubber to fill that gap!
And just to make sure, no issues hooking up to the current drive shaft right? Thanks again for the help on this one
post #6 of 6 (permalink) Old 10-27-2014, 09:22 PM
Quoted: 368 Post(s)
I may be wrong here, but Pontiac uses a big universal bearing cap and Chevy has a smaller one. You simply purchase a U-joint made to have both the Pontiac large caps and Chevy smaller caps. I vaugely recall having to do this once myself. NAPA should be able to help you on this. The U-joints are made by Dana Spicer. Just bring an end cap in from each size - if you need to do this.
Chevelle dash into my Lemans? torranosaurus 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 10-03-2013 08:16 PM
67 chevelle rad in 67 lemans bobby326 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 11-27-2010 01:27 PM
Rearend OrbitOrange 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 08-03-2010 09:48 AM
Rearend Marty 2004-2006 GTO General Discussion 107 10-17-2005 09:32 AM
