67 factory gto caliper? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-21-2014, 06:13 AM Thread Starter
https://www.nationalpartsdepot.com/s...arent=0&year=0
Will this work on my 67? It was optioned as factory disk brakes and is a 1 piston.But in the NPD catalogue and website I only find 69-newer gto listed. Any ideas guys? I have a front left caliper bad and need to replace it and don't want to spend a fortune at this time.
srea76 is offline
post #2 of 4 (permalink) Old 08-21-2014, 07:24 AM
67 Basket Case Restorer
Too Many Projects's Avatar
If your car has the single piston calipers, they are not original. Original were 4 piston. The link is for a single piston application and will interchange if yours is a newer conversion.
If you have a NAPA or other parts house nearby, you can get a rebuilt caliper from them quicker and without paying shipping.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #3 of 4 (permalink) Old 08-21-2014, 08:36 AM Thread Starter
Yes mine is single piston. I will have to try to pull it off and see if I can get a part number off of it. Thanks for quick reply.
srea76 is offline
post #4 of 4 (permalink) Old 08-21-2014, 10:16 AM
You have a conversion install and the single piston calipers interchange for about 20 years...'69~'89
There may be a casting number on the caliper body to reference what year it was made and use that as a guide for replacement application.
Mitch
1962 Impala SS
1938 Chev coupe
Caliper Rebuild Kit? Oldeboy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 12 10-01-2012 07:30 PM
caliper seals Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-13-2010 10:35 PM
caliper piston Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-05-2010 08:58 PM
hole in brake caliper Topkat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 11-27-2010 04:11 PM
