67 GTO 2 inch drop - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-18-2013, 09:48 PM Thread Starter
67 GTO 2 inch drop
I would like to see if anyone knows if I can use 17 inch tires and wheels on this car using 9 inch wide rear wheels and 8 inch front wheels with out tubing rear wheel wells?
jaddi62360 is offline
post #2 of 7 (permalink) Old 06-18-2013, 11:05 PM
I can't say for sure on a 67....
but it works on a 68
17 X 8s fronts
17 x 9s rears
Bill
bondobill is offline
post #3 of 7 (permalink) Old 06-19-2013, 07:13 AM
SANDU002's Avatar
A buddy of mine has 17's on his '66.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 7 (permalink) Old 06-19-2013, 07:04 PM
gotyorgoat's Avatar
Just make sure that you get the backspacing right when you order your wheels. 0 offset wheels will rub for sure.
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #5 of 7 (permalink) Old 06-19-2013, 07:24 PM
Quoted: 23 Post(s)
you can squeeze them in, 5" backspace i believe, problem will be the inner wheel well lip as it's 2" wide and may rub on bumps and hard corners or with passengers. I think Eric is running 17"x9" Billet specialty wheels on his blown black 67'.
Instg8ter is offline
post #6 of 7 (permalink) Old 06-21-2013, 09:43 PM Thread Starter
I originally thought I had a 2 inch drop but have found out today it has a 1 inch drop. Hotchkis 1 inch drop spring19930003. So I will need to do some thinking on this. I was told I can put another set of original springs and have room for a little more meat on my rear tires.
post #7 of 7 (permalink) Old 06-21-2013, 11:27 PM
Quoted: 23 Post(s)
Overall tire height should be close to the same no matter how tall your rims are (lower profile rubber, which will have less sidewall bulge), the width is what gets you in trouble. These cars have deep inner wheel house lips, they can be shaved or rolled in if you really want the extra meat. The fronts will tend to rub on the front bottom lip of the fender well on stock height cars at lock turn in the parking lot. I believe Rukee if running 15" 60R/295's on his 65' without alteration, that's the widest i have heard of. I saw a brand new Camaro with 18"x10" wheels filling up the wells, as i am riding up on him i am thinking how the hell....then i see his fender is mangled at the leading edge and all 4 of his outrageously expensive tires looked like they were run through an apple peeler. Always safer to compromise form for function.
65 GTO trunk drop off help ElMedioGringo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-18-2012 04:55 PM
1/2 inch fuel pump with 3/8 inch lines jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-18-2012 11:30 AM
drop spindles 1971 gto 71gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-16-2012 11:23 PM
Pedders GTO Street II 20mm drop GM.Rich Drive train, suspension, alignment and brakes. 10 02-25-2012 07:57 PM
How to drop compression of a GTO 389 extinctmake 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 55 03-26-2011 11:06 PM
