67 gto with 350 Pontiac will it hurt the value - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-07-2013, 05:48 PM Thread Starter
I am thinking of pulling my 455 motor and tranny out to put in a firebird and putting the 350 and the 4 speed in the gto to sell not sure how much it's going the hurt the value of the gto i do not have the matching number parts in the first place for the gto thanks for your thoughts
little goat is offline
post #2 of 9 (permalink) Old 07-07-2013, 07:51 PM
leeklm's Avatar
of course anything non-numbers matching hurts the value. I cannot imaging going from a non-matching 455 to a 350 (assuming similar value motors) is going to have a large impact. Maybe a grand or two, depending on the buyer. I am assuming you are not taking a $10,000 built 455, and replacing it with a $500 junkyard special 350?
leeklm is offline
post #3 of 9 (permalink) Old 07-08-2013, 09:43 AM
68greengoat's Avatar
The desirability factor will suffer. Most would rather have a 455 than a 350.... They are both non matching so the value shouldn't be affected much. The amount of people interested will be....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 9 (permalink) Old 07-08-2013, 10:40 AM
Quoted: 105 Post(s)
It will hurt the value of the car by 3 to 7 thousand dollars, the cost of locating and rebuilding a Pontiac 389-455 to put back in the GTO. A 350 in a GTO is a downgrade, and a negative factor in a muscle car. If I were to buy a GTO with a 350, my first thought would be on replacing the engine with something appropriate. That said, if you want the 455 for a Firebird, you'd have to pay $$$ to get another one to put in there.
post #5 of 9 (permalink) Old 07-08-2013, 04:49 PM
X2
Find a different motor for the firebird or drop the 350 in there.
post #6 of 9 (permalink) Old 07-08-2013, 05:12 PM Thread Starter
Ok thanks the gto was a 400 car 4speed I built a 455 with all the good stuff and a 6 speed going to try to find a 400 firebird the wife would go nuts if I if I built that same seat up I would have to get like 40k for the gto to let it go the way it is now and I do not see that with a 400 or a 350 would take some thing in the 20s I like the gto but don't want to cut it up to make a pro touring car out of it that is what I had plan it the first place
post #7 of 9 (permalink) Old 07-08-2013, 08:27 PM
Quoted: 368 Post(s)
Yep, a 350 is not a good choice for resale. Find a 400 and just do a stock rebuild. They offer an inexpensive rebuild kit with cast pistons that your machine shop can surely get for you. I used this kit on my '68 Lemans 400 in my first build and it kept the costs way down on the short block, but I added a cam, did the heads up right, and had some machine work done. I could have saved a little on the heads, but decided where I wanted to put my money and since I was not planning on spinning it to 6,000 RPM's anyway, felt the stock route was just fine. Used a 1972 engine with the 7K3 heads that ran on regular and still pulled like a mule and burned up the tires -I was happy and it didn't cost me an arm and a leg. You don't have to build a "big" engine, just a 400, and many would prefer a more stock engine so that they could drive it. Not everyone wants big HP.
post #8 of 9 (permalink) Old 07-08-2013, 10:14 PM
leeklm's Avatar
Good points. A pontiac 350 in a muscle car does lose its cool factor, even if it was putting out 400hp!
leeklm is offline
post #9 of 9 (permalink) Old 07-09-2013, 04:41 PM
teamwoody72's Avatar
I would stick with a gto motor. 400 motors are fairly easy to find
teamwoody72 is offline
Building a 72 Pontiac 350 AJ:) 1964-1974 Tempest, Lemans & GTO General Discussion 8 11-10-2013 11:31 AM
Pontiac 350 help TomM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-03-2011 11:49 PM
Pontiac 350 any good? OrbitOrange 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-18-2010 09:51 PM
Which carb for the Pontiac 350? gman26 1964-1974 Tempest, Lemans & GTO General Discussion 1 12-03-2005 02:30 PM
pontiac 350 ? freeyayo 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-19-2005 03:07 PM
