67 GTO fuel pump - Pontiac GTO Forum
post #1 of 22 (permalink) Old 10-11-2010, 07:44 PM Thread Starter
PisnNapalm's Avatar
67 GTO fuel pump
I'm thinking I need to change the fuel pump. I've got an oil leak at it's gasket. It also lets fuel drain back down through it when not running.
How difficult is it to replace? It doesn't seem like it's that hard, but looks can be deceiving.
Thanks again for any help.
PisnNapalm is offline
post #2 of 22 (permalink) Old 10-11-2010, 07:50 PM
Fairly easy. Disconnect and PLUG the fuel lines. (note which line goes where) Unbolt the pump and pull straight out. Clean and prepare gasket surfaces...reverse procedure to install.
Eric Animal is offline
post #3 of 22 (permalink) Old 10-11-2010, 08:05 PM Thread Starter
PisnNapalm's Avatar
Sounds about what I thought. Thanks.
Hey... Odd question.... Do people swap them out for electric pumps? Any advantage to doing that?
Also... Is it normal for fuel to drain back into the tank through the pump or is that a sure sign this one is shot?
post #4 of 22 (permalink) Old 10-11-2010, 08:16 PM
it is not normal for fuel to drain back to the tank like that. You could have a bad pump or carb problems....or a leaking fuel line between the tank and pump. Electric pumps are mainl used for High pressure/ high volume applications and for fuel injection....stick with the mechanical one for your car.
post #5 of 22 (permalink) Old 10-11-2010, 09:41 PM
jetstang's Avatar
When replacing the pump, if it's hard to align the holes, rotate the engine 180 degrees to get the pump off the pump lobe on the cam, just bump the starter til it bolts up easily.
I wouldn't go to an electric pump.
I just put a new motor in my 70 and used the old pump and it takes a bit to start the car, so I have the same problem. But, I swapped carbs and am blaming that, but am going to swap out the pump as it is cheap. Probably just junk stuck in the check valve.
Burning rubber since 1982!!
jetstang is offline
post #6 of 22 (permalink) Old 10-12-2010, 09:55 AM Thread Starter
PisnNapalm's Avatar
Just ordered a new pump from Ames Performance as well as a few other goodies.
Its got the early model pump without the vent tube.
post #7 of 22 (permalink) Old 10-12-2010, 01:54 PM
What else did you order?????
post #8 of 22 (permalink) Old 10-12-2010, 02:14 PM Thread Starter
PisnNapalm's Avatar
New window crank knobs, new bits for the sun visors to stop them from falling all the time, hmm.... new glove box and screws for it...
That's about it for now...
post #9 of 22 (permalink) Old 10-12-2010, 05:41 PM Thread Starter
PisnNapalm's Avatar
Dang... Ames Performance is quick. I order it this morning and just received the UPS tracking number. I will likely get to swap the new pump in this weekend.
post #10 of 22 (permalink) Old 10-12-2010, 06:43 PM
AMES has been around for a long time. They are a real good company.
fuel pump eccentric gman26 1964-1974 Tempest, Lemans & GTO General Discussion 11 10-15-2013 01:07 PM
70 GTO 400 Fuel Pump Installation Problem!! NEEDLEZ 1964-1974 Tempest, Lemans & GTO General Discussion 6 10-22-2009 07:28 AM
New Fuel Pump? Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 16 05-03-2009 05:47 PM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
64 GTO Fuel Pump Bolts? goat1964-2004 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-22-2007 06:33 AM
