'67 GTO Harmonic balancer and pulley - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-23-2010, 06:53 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
My 400 ci GTO motor is missing is haermonic balancer and pulley.
After ther timing chain geag and cover go on, it dosn't look like the is much room at all to mount the balancer.
How does it go on there?
The manual is so vague...
Also it dosnt look like much of the crankshaft key is long enough to slide the balancer onto.
What gives?
Thanks in advance
Topkat is offline
post #2 of 2 (permalink) Old 09-23-2010, 07:15 AM
The balancer hub slides onto the crank, thru the bottom of the timing cover....the timing cover has a seal in it which makes the hole LOOK small. You should replace the seal prior to re-assembly. You can replace the seal while the timing cover is on the engine, but the work is more difficult. Eric
Eric Animal is offline
harmonic balancer 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-27-2010 01:30 AM
harmonic balancer/underdrive Richtenb Engine Discussions 4 02-24-2010 07:34 AM
How to remove the Harmonic Balancer Joust 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-14-2009 08:56 PM
Harmonic Balancer anyone ever have one go bad on an LS1 fergyflyer Engine Discussions 10 11-13-2008 08:09 AM
