67 GTO Positive Battery Cable Routing - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-26-2014, 06:18 PM Thread Starter
Can anyone give me any guidance on the routing of the positive battery cable on a 67 GTO as it would have been out of the factory? I know where it starts and ends, but just looking for in between. Also, is the heat shield tube you can buy also stock or an add on? And, if you could confirm the length on non HO/Ram Air GTO (no air, power brakes, power steering, power windows, etc.) is 42 inches, I'd appreciate that too. Thanks in advance!
Kev0477 is offline
post #2 of 2 (permalink) Old 05-30-2014, 02:07 PM
Quoted: 117 Post(s)
Roger that on the 42 inch length. The cable goes from the starter, up thru the metal heat shield tube that's bolted to the head between #5 and #7 cylinders, and then it attaches to the fender liner (wheel well tub) with a couple of plastic clips. Frome there, to the Battery. Super simple.
Battery Cable Routing MAP53 1964-1974 Tempest, Lemans & GTO General Discussion 4 04-12-2014 07:23 AM
Positive Battery Cable Shield voltaire 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-16-2013 09:40 AM
New Battery Cable Oldeboy 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-23-2013 10:15 AM
Battery - Connection on Positive Seems to Have Eroded noel the legend Service, Maintenance and Technical Discussion 7 03-07-2012 10:36 AM
