67 GTO rear light assembly leaks - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-08-2013, 03:07 AM Thread Starter
Hi again,
Water is able to get in around the gap between the rear light assemblies and the body - is this common? Should it have a seal, and if so, are these available? If not, any tips how to seal it with a sealer eg seal from inside trunk or seal externally (which may look bad).
The rear window leaks too - need to investigate that also but water is getting in trunk.
Paul
pcolenutt is offline
post #2 of 3 (permalink) Old 06-08-2013, 07:29 AM
Originally Posted by pcolenutt View Post
Hi again,
Paul
Yes it is commom on 67's. Talk to. MY67GTO on here. He has "the solution".
post #3 of 3 (permalink) Old 06-12-2013, 03:13 PM Thread Starter
Thanks Bear.
1969 GTO Rear Tail Light Harness SW63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-08-2012 01:10 AM
Rear GTO light goat400 2004-2006 GTO General Discussion 1 09-01-2009 01:45 PM
Rear Qtr Glass window guide assembly Chris Holabaugh 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 05-18-2009 01:03 PM
Help with rear courtesy light 69 GTO conv. cwcwood Interior Discussions 0 04-30-2008 09:37 PM
