67 GTO Tach problem - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-29-2014, 03:42 PM Thread Starter
lms1077's Avatar
67 GTO Tach problem
Hello,
For the past month i have been trying to get my old tach repaired, but the part was on back order. Finally it came yesterday and I installed it right away.
However the happy ending i thought would come did not.
The new tach does not work at all. No movement.
I have the dash taken apart and just wanted to test the tach, so none of the other instruments in the cluster were hooked up.
When i started the car, and did not see the needle moving, i tried wiggling the wires a little and could feel a charge from the two black wires coming from the wiring harness.
In the attached pic, the old tach is on the left and the new one is the one screwed into the cluster.
If anyone can provide any advice I would appreciate it.
lms1077 is offline
post #2 of 2 (permalink) Old 08-02-2014, 05:55 PM
crustysack's Avatar
if there is no movement at all the you either have a bad new tach ( possible but unlikely) or a broken wire/ bad connection-( highly probably)- the ground wire is short and easy to eliminate, trace the 12v power wire and see if it is split somewhere or grounding out to the chassis/body some where, 40+ year old wires can break anywhere along the harness- put a voltmeter on the wire and see if you are getting anything- you can also try running a wire directly to your coil to see if the signal wire is no good
crustysack is offline
Tach problem GTO viking 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-18-2012 04:29 PM
1966 GTO In-dash Tach Hutch7271 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 06-13-2011 12:17 PM
'66 GTO factory Tach Howard Jeffrey 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-23-2008 05:55 PM
question RE Hood tach 67 gto blondie67 1964-1974 Tempest, Lemans & GTO General Discussion 9 01-28-2008 08:13 PM
