67 harmonic balancer - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-16-2012, 08:49 PM Thread Starter
How do I know if the harmonic balancer is shot. The 67 harmonic balancer is a 2 part setup, 3 if you count the spacer. The part of the balancer that sits inside the pulley has an inner and outer donut and there is a rubberized divider between the two. And I can spin it the outer donut around the inner part. Is the rubberized piece shot and worn out or is it suppose to spin. Meaning I need to buy a new harmonic balancer.
my67goat is offline
post #2 of 5 (permalink) Old 04-16-2012, 08:58 PM
You will need to buy a new one, it should not spin. All 3 parts should be bonded together, inner rubber, outer .
fasterfiero is offline
post #3 of 5 (permalink) Old 04-18-2012, 05:23 AM
allpawl66's Avatar
Have a good one from a 67 400 engine if needed .
allpawl66 is offline
post #4 of 5 (permalink) Old 04-18-2012, 06:52 PM
If you can move it at all, it's toast. Don't run the engine until you've taken care of this. You're taking a huge risk with your main bearings if you do.
post #5 of 5 (permalink) Old 04-21-2012, 09:38 AM Thread Starter
balancer
Thanks guys a new one is on order.
my67goat is offline
Harmonic Balancer. Help!!! Seol21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-04-2011 12:35 AM
Harmonic Balancer? SWOOSH 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-09-2011 06:50 PM
Harmonic Balancer YellO5LS2 Engine Discussions 1 01-20-2011 09:33 PM
65 389 harmonic balancer torpedo51 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-02-2010 11:50 PM
harmonic balancer 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-27-2010 01:30 AM
