'67 heater core - Pontiac GTO Forum
post #1 of 17 (permalink) Old 10-16-2009, 08:17 PM Thread Starter
'67 heater core
Second post for me. Probably more to come. My step-father had a '67 GTO and he passed away this year. It's now my mothers and I'm, by default, tasked with maintaining it. I'm trying to find out what's the best place to buy a new heater core and possibly the heater box. The car has been in storage and he ran it 2 years ago but not since. I went to look it over and found a nice puddle on the passengers floor. Pulled the heater core out (!!!) and it's been leaking and the box is corroded too. Need to find parts. Do you guys have certain places that are good suppliers of parts? I found a core at Chicago Muscle Car Parts for $45.00 and it shows the box as used but no price. Is the $45 a fair price? Any ideas on the box? Thanks in advance.
Crikker is offline
post #2 of 17 (permalink) Old 10-16-2009, 08:29 PM
67 Basket Case Restorer
Too Many Projects's Avatar
First......welcome to the forum.......
The price for the heater core is fair, provided it's a quality piece. As far as the box, is it corroded thru ? If it's just surface rust, have it bead blasted and paint it. Otherwise, used heater boxes turn up for sale quite often as they are the same for other models as well. There are many thousands of them out there. The price of a replacement one will vary on the condition but I don't think I'd pay more than $50-60 for a nice one.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #3 of 17 (permalink) Old 10-17-2009, 06:17 AM
Which heater box, on the firewall in the engine compartment or the one under the dash? I have a non A/C box for for the engine compartment. You will also need a new gasket kit, I buy most of my parts from The Parts Place
05GTO is online now
post #4 of 17 (permalink) Old 10-17-2009, 06:54 AM
crustysack's Avatar
i have a complete unit out of a 65 that should fit-non ac heater box, core, blower motor etc that needs nothing everything works fine all actuators move smoothly,motor spins effortlessly, just a little bit of surface rust inside the box I took it out because i went with a vintage air ac system- I'll sell it for $75 + shipping pm if interested
ID:	5699   Click image for larger version
ID:	5700   Click image for larger version
ID:	5701   Click image for larger version
crustysack is offline
post #5 of 17 (permalink) Old 10-17-2009, 04:00 PM
Quoted: 102 Post(s)
'65 is different. I know because I'm doing some cable repair on my '67, and I was looking at my '65 as a reference, and they are not the same. '66 will work, though.
post #6 of 17 (permalink) Old 10-17-2009, 04:32 PM
crustysack's Avatar
thanks- i thought they were all same 64-67
post #7 of 17 (permalink) Old 10-17-2009, 05:50 PM Thread Starter
I think I may be able to clean up the box. I'll try that first.
Can't get ahold of Chicago Muscle Car. The Parts Place has a core for $60. I'm also trying to find the pad that is directly above the heater box. This one came out in three pieces and a bunch of smaller ones. Pretty shot. Parts Place called in the firewall pad but I would guess that's the seal from the box to the firewall. What would be the correct name for it so I could ask them?
Crikker is offline
post #8 of 17 (permalink) Old 10-17-2009, 07:07 PM
Eastwood has some very good products to spray on light rust that stops it from getting worse and is paintable. If you don't have access to a sand blaster, I recommend using the rust stop first.
There are 2 pads in that area. If it lays on the firewall behind the heater box, inside, it should be the firewall pad. If it is the fiberglass type insulation that was originally glued up under the dash. It's the dash insulation. Here's a pic of a firewall pad for reference. It goes all the way across to the steering column.
Mitch
1962 Impala SS
1938 Chev coupe
post #9 of 17 (permalink) Old 10-18-2009, 11:09 AM Thread Starter
Thanks Too Many Projects. I emailed them back with that description. Hope they have it.
Crikker is offline
post #10 of 17 (permalink) Old 11-17-2009, 06:22 PM Thread Starter
Well, I received the heater core, cleaned up the box and repainted it. Doesn't look half bad.
I still can't find the dash insulation. The Parts Place sent me a one piece fiberglass insulation kit. It's 4" wide by 2 ft long and it's 1 inch thick. The stuff I pulled out of there was real thin (1/2" maybe) and was punched through with, what I'm assuming, are the shapes of the parts under the dash. I can't find a good parts picture but if you guys could look at this site,
Chicago Muscle Car Parts - 1967 GTO/LeMans
and under Heater Parts, there is a Underdash Insulation Kit (3 piece) #7 that I think may be what I'm searching for. Does anyone have any good links to a picture breakdown of the insulation? Sorry for the long post.
Crikker is offline
Heater fan speed issues droptop69goat 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 9 05-13-2017 04:37 PM
Heater Core Replacement For 1966 Gto take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-02-2009 08:39 PM
Heater core replacement 1969 gto silky58 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-30-2009 04:29 PM
69 Heater Core ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2009 06:42 PM
