67 Lemans tire question - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-10-2016, 07:31 AM Thread Starter
I have a 1967 Lemans GTO clone and am looking to get new tires. The ones that are currently on it are 225/70/15. The wheels are rally ii's. What other sizes would work with that wheel? Any recommendations?
67455goatclone is offline
post #2 of 6 (permalink) Old 02-10-2016, 11:14 AM
Quoted: 106 Post(s)
I have a '67 GTO with the same rims and 225/70/15 rub on the front when I would turn.
Brand new Redlines I can't use.
I had to go to a lower aspect ratio 235/60/15 T/A radials.
Goat Roper is offline
post #3 of 6 (permalink) Old 02-10-2016, 01:26 PM Thread Starter
I've had the same problem with my 225/70/15's on the front passenger. I was thinking of going with 215/70/15 up front with 225/70/15 out back.
post #4 of 6 (permalink) Old 02-10-2016, 02:01 PM
Quoted: 106 Post(s)
215/70/15 will still rub in the same spot , you may get away with a 65 but it calls for a 60.
I tried the 215/70/15 and that is why I have 6 Redlines I can't use instead of 4.
The 225/70/15 will work on the back but not much clearance between the fender lip and the tire.
post #5 of 6 (permalink) Old 02-10-2016, 04:10 PM Thread Starter
so the 235's are not to wide? The height seems fine but the width seems to wide.
post #6 of 6 (permalink) Old 02-10-2016, 04:28 PM
Quoted: 106 Post(s)
No, the aspect ratio (height) not the width is the problem.
235/70/15 will rub, 235/60/15 won't.
225/60/15 T/A radial is what are recommended.
67 gto lemans 17" rim tire size help bbetz999 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-14-2015 06:49 PM
Tire Question bradc2009 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-16-2013 06:04 PM
70 LeMans Sport - Tire Size bigmackloud 1964-1974 Tempest, Lemans & GTO General Discussion 9 06-08-2013 07:06 PM
gto/lemans tire fitment Pontiachris 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-18-2011 09:25 PM
biggest wheel and tire combo on rear 69 Lemans Kip Page 1964-1974 Tempest, Lemans & GTO Wheels & Tires 4 10-25-2009 11:08 AM
