67 Pontiac 400 w/670 heads. Need Advice - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-08-2017, 10:49 AM Thread Starter
Nelson Musgrave's Avatar
So, I just bought a 1965 pontiac Tempest Custom (GTO Clone). It has a 67 YT 400 w/ 670 heads. The guy that i bought it from said it had a mild cam (of course he didn't know the specs). He did not know of anything else done to it. Hell he did not even know that it was a 67 motor until i told him. So with all that said. I know nothing about these 670 heads. What fuel do i need to run? It is a street car, daily driver. i have drove it several times already with 92 octane. But please tell me if i am wrong or if I should get new heads for the street. Thank you in advance.
1965 Pontiac GTO
400CI
Turbo 400
Nelson Musgrave is offline
post #2 of 5 (permalink) Old 08-08-2017, 01:36 PM
Quoted: 106 Post(s)
Welcome to the forum.
You don't know what the compression ratio is and usually if the compression has been lowered to 9.5-1 to run on the new pump gas it is done with the pistons not the heads.
Do you experience pre ignition?
My engine is built 9.5-1 and runs good on 89 octane.
You don't need new heads to run it on the street.
Goat Roper is offline
post #3 of 5 (permalink) Old 08-09-2017, 03:02 PM Thread Starter
No i do not know the compression ratio. Like i said i just bought the car and haven't torn into the motor. So far i haven't had any pre-ignition or detonation. I will find out the compression ratio soon
1965 Pontiac GTO
400CI
Turbo 400
post #4 of 5 (permalink) Old 08-10-2017, 10:03 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Here's a thread about the 670 heads and discusses compression and other info you probably want to know. Hope this helps you some.
670 heads popularity ? - PY Online Forums
1968gto421 is offline
post #5 of 5 (permalink) Old 08-10-2017, 10:07 AM
Quoted: 106 Post(s)
Does it run good?
No smoke or low oil pressure?
Why do you want to tear into the motor?
400 Pontiac Engine Advice rossph 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-23-2015 02:02 PM
670 heads harleynut45 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 07-10-2014 09:49 AM
#670 or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 12-01-2011 09:24 AM
670 heads 68gtohawk8369 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 10-11-2010 10:59 AM
670 heads journeymate 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 11-13-2009 03:26 PM
