67 PS Pump - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-02-2010, 05:31 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
67 PS Pump
Is the pulley on my 67 Goat's PS pump pressed on?
It has a nut on it........
It's so nasty , and the cap wont stay on I will probably replace it/
thanks as always
Topkat is offline
post #2 of 5 (permalink) Old 12-02-2010, 05:36 PM
Old Goat 67's Avatar
Not pressed on, but you will need a small puller to get it off. It is keyed on the shaft.
Old Goat 67 is offline
post #3 of 5 (permalink) Old 12-02-2010, 07:06 PM
Quoted: 118 Post(s)
X2. They never slide off w/o a puller....at least not for me. There is a special puller just for PS pulleys. OTC may have it....
post #4 of 5 (permalink) Old 12-02-2010, 07:30 PM Thread Starter
Topkat's Avatar
I got the sucker off with a pickle fork.lol
er...........this thing is extremely nasty and has been sitting a minimun of 15 years.(yet so has everything else and so far so good)
I wonder of the seals and integrity of the pump.
Can I clean it up, and put some type liquid in it to see if it leaks?
Or just replace the sucker...
Topkat is offline
post #5 of 5 (permalink) Old 12-02-2010, 08:13 PM
Depends on your budget I guess, but ps pumps run about 35-40 bucks for a rebuilt one without the reservoir, 40-50 with a reservoir, and a little more than that for a new one. For that kind of money, it's hardly worth fooling around with the old one unless having 'the original' matters to you a whole lot.
water pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-22-2010 01:02 PM
67 GTOwater pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 11-19-2010 07:52 AM
pump question wytnyt 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-20-2008 07:28 PM
Pump you up VettenGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-26-2008 07:49 AM
05 Oil Pump GTOGuy Service, Maintenance and Technical Discussion 1 09-22-2005 09:02 AM
