67 PS Pump - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-22-2011, 05:55 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
67 PS Pump
Why are there 2 adustments for my 67 ps pump?
One is on the rear right(looking rearward) t'other on the left front.
I know I have the correct belt. But am having a hell of a time getting the belt tight. It dosn't seem one can be moved without the other one moving.
what am I doing wrong?
any advise?
thanks as always
Topkat is offline
post #2 of 2 (permalink) Old 04-23-2011, 02:02 PM
Quoted: 103 Post(s)
They both move together. You loosen both (the one on the left is hard to get to) and you use a prybar against the tang on the bracket. Then you tighten it up. You may not have it assembled properly if it's a struggle. It's a very simple and easy adjustment.
water pump Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-06-2011 12:27 AM
67 PS Pump Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-02-2010 08:13 PM
67 GTOwater pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 11-19-2010 07:52 AM
oil pump? Pontiachris 1964-1974 Tempest, Lemans & GTO General Discussion 11 03-06-2010 11:22 AM
Pump you up VettenGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-26-2008 07:49 AM
