'67 vacuum gauge placement - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-19-2016, 05:18 PM Thread Starter
Anyone know if there is a template for a vacuum gauge placement for a '67 or if it is marked under the console like a '66 ? Did a search and did not find a
good answer.
pony462 is offline
post #2 of 4 (permalink) Old 01-19-2016, 06:18 PM
Lemans guy's Avatar
Quoted: 69 Post(s)
Not sure there was ever a factory place for one, just mounted mine on console under the dash, Vacumn hoses are just above to heater controls, you can slice in wherever you like, I went into engine compartment for a good Vacumn.....
Lemans guy is offline
post #3 of 4 (permalink) Old 01-19-2016, 06:35 PM
pjw1967's Avatar
Option list for '67 shows as a factory item, not dealer. So you assume there was a standard for placement. I Googled images for one and found this. Looks like you could estimate the placement based on this photo if in fact it was factory-installed.
https://www.google.com/search?q=imag...EdIVyHrL-hM%3A
pjw1967 is offline
post #4 of 4 (permalink) Old 01-19-2016, 07:03 PM Thread Starter
PJW Thanks so much for the info. I can work with that, very good job. If you happen to come across any info on the reclining seat actuator for the pass. side bucket seat for a '66-'67 please pass it along. Thanks again.
pony462 is offline
1968 GTO AC/Heater inside vacuum line placement schematic rlangrid 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 12-21-2015 01:55 PM
1966 tri power vacuum lines placement xkeots 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-24-2014 11:24 AM
Vacuum Gage placement????? Rowdygto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 28 10-02-2014 07:26 AM
Vacuum gauge gtoearl 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-13-2012 10:18 PM
Vacuum Gage placement????? Rowdygto Gtoforum.com Site Help 1 10-12-2008 10:09 AM
