68 conv. crossmember - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-31-2012, 10:02 PM Thread Starter
Does anyone know if a 68, lemans (gto clone) convertable, uses the same crossmember as a hard top? What years will interchange??
Thanks, Duck
1coolduck is offline
post #2 of 3 (permalink) Old 10-31-2012, 11:34 PM
crossmember
just went through this about 4 hours ago with the '66 Lemans ragtop. Pulled 326 w/st300 out. Put 455 w/th400 in. I read an old post awhile back about the coupes & convertibles having different crossmember locations. that was for a '66, though. Not sure about 68's. Will do a little creative weld modification on the crossmember. You might have to do the same.
gjones is offline
post #3 of 3 (permalink) Old 11-04-2012, 02:46 PM
Thanks, Duck
The short answer is no they are not the same piece due to the convertible having a boxed in framed, therefore it is narrower between the rails of a convertible than that if a hardtop. Now the LeMans convertible and the GTO convertible use the same cross member.
mrvandermey is offline
transmission crossmember question SammyLJ 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 03-08-2012 03:34 PM
Oil pan on crossmember MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-04-2011 11:49 AM
Missing Crossmember Bushing! wakerider017 Drive train, suspension, alignment and brakes. 0 05-06-2006 11:37 PM
