68 Gas Tank - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-18-2010, 11:59 AM Thread Starter
68 Gas Tank
I have to replace the gas tank in my '68 GTO. It is leaking too many places to fix. All the aftermarket tanks for the '68 come without the filler neck. The '69-70 tanks look the same, but come with the filler neck. Any reason I can't install a '69-70 tank?
dhinnah is offline
post #2 of 6 (permalink) Old 12-18-2010, 03:45 PM
ThePartsPlaceInc.com lists the same tank, their part number FT2384G, for 68, 69, and 70. It comes with the filler neck.
post #3 of 6 (permalink) Old 12-22-2010, 01:17 PM Thread Starter
Here is the reply from Ames:
The angle of the filler neck is precisely why the 68 tank is unique. The way that it lines up with the bumper is different for that year. You will need to reuse the filler neck in this situation. We to offer a tank for 1968 but only without the neck. Nobody has tooled for that one year only neck at this point that we know of.
Thanks for checking with us,
Ames Performance Team
dhinnah is offline
post #4 of 6 (permalink) Old 12-22-2010, 01:59 PM
Glenn's Goat's Avatar
wow that sucks, i supposed your gonna have to have a good welder lay a bead around that neck.
Glenn's Goat is offline
post #5 of 6 (permalink) Old 12-22-2010, 07:41 PM
I took mine to the radiator shop. He took some measurements and swapped it out. It did not take very long.
dimitri is offline
post #6 of 6 (permalink) Old 12-22-2010, 09:12 PM
jetstang's Avatar
Take it to a muffler shop and put the neck on a bender, that may work. Good luck and sorry for the PITA!!
Burning rubber since 1982!!
jetstang is offline
Gas tank help guyman 1964-1974 Tempest, Lemans & GTO General Discussion 6 07-12-2015 03:57 PM
gas tank Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-10-2010 12:12 PM
Gas Tank Vacuum twisted 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-23-2009 05:21 PM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-03-2006 11:45 PM
Moving the gas tank disposablehero Service, Maintenance and Technical Discussion 11 09-21-2005 08:12 PM
