68 GTO Instrument Swap - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-12-2016, 11:56 PM Thread Starter
I just picked up a 68 GTO with little needed and other than fixing the fuel gauge, would like to make a couple simple changes. The first is to try and swap out the original oil pressure and temp lights with an actual gauge which I believe Pontiac offered as an option. I'm not having much luck finding an original one as wanted to know if in fact they exist and if so, if it's as easy as swapping out the gauge and sending units.
bgumpper is offline
post #2 of 4 (permalink) Old 02-13-2016, 09:13 AM
rally gauges are what you are after. Pontiac placed rally gauges in the same basic rally guage housings for '68-72 A body's in the following styles:
-'68...grey blue background gauges
-'69...dark grey back ground with 120 speedo
-'70-mid year '72...dark grey background w 140 speedo
-late '72...dark grey with 120 speedo & seat belt warning light.
For a '68, you'll most like likely want a '68 set. they occasionally come up for sale in nice shape with no fine rust spots on the gauge faces. The far rh opening is for an in dash tach or a factory clock. Not to dicourage you, I've pulled a ton of dash bezels and factory gauges out of GM A bodies and '68 Tempest/LeMans/GTO's are one of the most difficult to work on/remove. Heading out for the day, will post back with some tips on how to get the gauges out.
post #3 of 4 (permalink) Old 02-13-2016, 10:50 AM Thread Starter
Thanks for the info. I already have a tach so was just hoping to swap out the gauge with lights for one with meters. I just assumed the look will be the same as what I have if the gauge is year correct.
bgumpper is offline
post #4 of 4 (permalink) Old 02-15-2016, 10:05 PM
Try here. Precision Pontiac Rally Guages
Pete's a great guy. I picked up a real nice condition set of gauges from him just recently.
backinhs is offline
1974 GTO instrument panel Injun Don 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-02-2013 09:22 AM
How to remove instrument cluster from 1965 GTO? acs1123 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-27-2012 04:35 PM
Dash Instrument Removel 67 GTO harleynut45 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 02-15-2012 07:23 AM
67 GTO Instrument Panel Insert steve grossman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-19-2010 04:39 PM
2004 GTO Instrument Cluster Lens chucksgto Interior Discussions 9 01-24-2009 06:41 PM
