68 GTO Options Question - Pontiac GTO Forum
post #1 of 14 (permalink) Old 06-28-2009, 05:35 PM Thread Starter
Lukeduk1980's Avatar
Send a message via Yahoo to Lukeduk1980
Benn finding out more and more on the GTO, including that the motor was a performance rebuilt. Unknown on the HP.
My question is this, Did the 1968 Pontiacs have the option of having a Hurst shifter installed on the vehicle or was that strickly aftermarket???
Lucas
Lukeduk1980 is offline
post #2 of 14 (permalink) Old 06-28-2009, 07:58 PM
68greengoat's Avatar
GTO's did come with Hurst shifters from the factory. I have a brochure from '68 that specifically talks about Hurst shifter in the GTO's.
68greengoat is offline
post #3 of 14 (permalink) Old 06-28-2009, 07:59 PM
67 Basket Case Restorer
Too Many Projects's Avatar
As far as I know, Pontiac opted to use Hurst shifters exclusively in the early 60's and your 68 would've had a Hurst from the factory. Too bad Chevrolet was so cheap and used the junk Muncie for so long...
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 14 (permalink) Old 06-28-2009, 09:24 PM Thread Starter
Yeah, Also the rear end is a 12 bolt but has a 4 linkage setup, 2 on the top and two on the bottom with coil over springs. was this a gto setup or something else?
Lucas
post #5 of 14 (permalink) Old 06-28-2009, 09:30 PM
That's definitely a modification. No GM cars came with a cool setup like that....we need pics of it. The axle is most likely from a Chevelle.
Mitch
1962 Impala SS
1938 Chev coupe
post #6 of 14 (permalink) Old 06-28-2009, 11:08 PM Thread Starter
Looks like a 12 bolt "Safe-T-Track" rear end. Does that sound right for the typical 1968 GTO rearend?
post #7 of 14 (permalink) Old 06-29-2009, 11:18 AM
It's a swap.
GTO's came with 10 bolt rear ends.
You scored.
Silver69GTO is offline
post #8 of 14 (permalink) Old 06-29-2009, 12:08 PM Thread Starter
More confusion
OK, did alittle research, I have found some GTO's with the Safe-T-Track rearend in them. They were used on 455's and 400's with the HO motor. I definately need to get the information from PHS so I can comfirm this. This does not look like a addon but it is possible. its got a frame members just above the rear axle that holds the upper linkage setup. I dunno what is going on. But I did find just a few out of all the gto i've looked at that had the safe t track in it.
Also, as for the hurst shifter, it is called a his & hers shifter. what that setup common also on tghe GTO's?????
Lucas
post #9 of 14 (permalink) Old 06-29-2009, 01:04 PM
All '68 GTO's had the safe-t-track(posi) option. The gearing ranged from 2.56 - 4.33. All manual transmissions with floor shifters were Hurst. His/Her shifters were used in floor mounted automatics. They were both Hurst......
post #10 of 14 (permalink) Old 06-29-2009, 01:12 PM Thread Starter
Cool, well that explains that. I have the Safe-T-Track rearend (12 bolt) and the His & Her's floor Hurst shifter in it. It does have the automatic in it. Hopefully, its a matching numbers rear end. Does this mean that my engine was a 400 High Output motor originally???
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
69 Judge-need your opinions, please joeflyer 1964-1974 Tempest, Lemans & GTO General Discussion 11 08-03-2006 12:24 AM
Holden to end production of Monaro but Pontiac GTO to Continue 05GTO In the News 7 08-05-2005 08:17 PM
GTO owners,i Got a buying/monthly Question logigamer Southeast 1 03-22-2005 03:16 PM
