68 gto qjet vacuum hose routing? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-17-2018, 09:00 PM Thread Starter
Quoted: 13 Post(s)
Anyone have a clear picture of how the hoses route? 400 with 4 speed.
Supersport#68 is offline
post #2 of 7 (permalink) Old 11-18-2018, 04:48 PM
integrity6987's Avatar
Quoted: 51 Post(s)
also depends a little on options like power steering or hidden headlights.
DK
integrity6987 is offline
post #3 of 7 (permalink) Old 11-18-2018, 04:50 PM Thread Starter
Quoted: 13 Post(s)
Factory Power steering, power brakes, and non factory hidden headlights, carb 7028267 we number
post #4 of 7 (permalink) Old 12-01-2018, 01:02 PM
Quoted: 51 Post(s)
Sorry for the delay.
This is "all stock" based on my research, for a 4sp (so w/ 5 port thermo vacuum switch) PS, PB, Hidden headlights. Also has the vacuum retard module (the 3 port cylinder to the left) to the 1 year only dual port distributor vacuum advance / retard you can't see in the pic.
DK
post #5 of 7 (permalink) Old 12-01-2018, 10:39 PM
Quoted: 79 Post(s)
Helpful photo. Thanks for posting. Carb in that pic is for an automatic transmission.
I am still on the hunt for a photo of a 1968 7028273 carb to see if it has the tube in the base behind the vacuum pull off. I have yet to see a 273 carb with that tube.
Shake-N-Bake is offline
post #6 of 7 (permalink) Old 12-02-2018, 09:33 AM
Quoted: 51 Post(s)
This is PN7028267 for the carb in the picture (WS code engine). Matches Tom DeMauro's book page 52, which agrees with Eric White's book page 33.
You are also correct (I'd forgotten I did add the shiny vacuum manifold that has one extra port. My car was "born with" manual brakes.
The other picts are ones I found on web of a supposedly all original 1968 HO.
ID:	116565   Click image for larger version
Name:	Original GTO profile.JPG
ID:	116567   Click image for larger version
Name:	Original GTO - HO engine (2).JPG
DK
post #7 of 7 (permalink) Old 12-02-2018, 11:14 AM
Quoted: 79 Post(s)
7028267 is correct for WS applications but shouldn't have a vacuum port on the front to the upper left of the fuel inlet (as you look at the carb). That port is used for shift modulation in automatic transmissions.
I know Carter made some carbs for GM to supplement Rochester. Maybe they installed that fitting and then capped it for manual trans usage?
Vacuum Hose Hookup at "Rotary Vacuum Valve" rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 08-29-2015 07:12 PM
68 GTO Windshield washer hose routing FlambeauHO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 12-10-2013 04:05 PM
Vacuum hose routing for hideaways? petet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-10-2013 11:42 AM
Vacuum advance hose routing 4 speed mbergin 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-14-2012 09:48 PM
Quadrajet Vacuum hose routing.... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-15-2009 04:29 PM
