68 GTO Rear courtesy light lamp replacement - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-22-2014, 03:03 PM Thread Starter
Quoted: 4 Post(s)
We have a 68 GTO Convertible and one of the rear courtesy arm rest lamps is out. It is positioned on the side molding below the rear arm rest, but can't see any screws to remove the lamp cover and get to the bulb. Does anyone know if I have to completely remove the arm rest to get to the lamp, or is there a easier way to get the lamp cover off and replace the bulb? Thanks.
mwatson1647 is offline
post #2 of 3 (permalink) Old 11-22-2014, 03:46 PM
jmt455's Avatar
The lens is held in by snap tabs.
Remove the lens (be careful not to break the tabs) to gain access to the bulb.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 3 (permalink) Old 11-23-2014, 11:05 AM Thread Starter
Quoted: 4 Post(s)
jmt455, THANKS AGAIN!!
A/C duct blocks the courtesy lamp? 70conv 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-24-2014 08:06 PM
Help with courtesy lamp issue... 70conv 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-06-2012 07:31 PM
1965 CONV. rear courtesy light removal BARONYOUNGMAN 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-01-2011 02:15 PM
66 Tempest Courtesy Lamp Replacement TempestTamer 1964-1974 Tempest, Lemans & GTO General Discussion 2 04-26-2010 03:04 PM
Help with rear courtesy light 69 GTO conv. cwcwood Interior Discussions 0 04-30-2008 09:37 PM
