68 Ignition Switch - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-28-2014, 07:25 AM Thread Starter
kilkm68's Avatar
68 Ignition Switch
Having trouble removing the ignition switch in the dash of my 68. I was told to put a paper clip in the small hole, rotate it counter clockwise and it will pop out. That's not happening. I tried spraying a little PB blaster in the hole and let it sit over night, didn't help. Any advice?
kilkm68 is offline
post #2 of 2 (permalink) Old 06-28-2014, 08:57 AM
I think that's just for removing the keyed cylinder only. Doesn't the bezel unscrew from the dash panel? Small chrome ring that holds it in, unscrew it and remove it from the back. this part here:
http://www.opgi.com/gto/G240425/
666bbl is offline
67 Ignition switch lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2012 02:44 AM
Ignition switch GTO -68 GTO viking 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 04-20-2012 01:51 PM
new ignition switch BillGTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-26-2009 02:34 PM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-25-2009 11:58 PM
Ignition Switch? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-29-2007 10:13 PM
