69 GTO 400 block Short or long water pump - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-06-2012, 12:11 PM Thread Starter
jtwoods4's Avatar
My engine builder called me today and asked me if I need the short or long water pump. I have a 1969 GTO with the original 400 engine block. I'm not sure if I nedd the short for long water pump. He said the pullies and brackets would not line up correctly if the wrong length was used. Any help you would be greatly appreciated. I guess I'm going to reuse the pullies of the existing 455 that is in the car now
jtwoods4 is offline
post #2 of 4 (permalink) Old 12-06-2012, 03:37 PM
There were two pumps used in 69. Early in the model year there was a short snout pump (4" from flange to shaft end), later in the year Pontiac went back to the long snout (4 1/2" from flange to shaft end). You can guess based on the date code on your engine whether it's an early or late production, but it'd be better to measure.
The Beast was an early production 69 but I converted it to use a long snout pump - and yeah, it was quite a challenge to get it all right.
post #3 of 4 (permalink) Old 12-08-2012, 01:17 PM
Just a thought-if your 'engine builder' can't grab a tape and measure it for himself, he probably has no business working on your car lol.
etewald is offline
post #4 of 4 (permalink) Old 12-09-2012, 02:20 PM Thread Starter
jtwoods4's Avatar
I don't think you understand... my engine builder does not have the pully set up that I'm going to use he needs me to measure my existing water pump on the engine in my car. He is building another engine.
jtwoods4 is offline
Long or Short AaronGough Intake and Exhaust Discussions 16 02-03-2009 10:23 AM
long or short HoldenGTO Intake and Exhaust Discussions 5 07-29-2007 01:30 PM
Short or long tube? GTO6 2004-2006 GTO General Discussion 11 12-30-2006 11:51 AM
Problem with Short Fills at the Pump? b_a_betterperson Service, Maintenance and Technical Discussion 17 07-15-2005 02:11 PM
