69 GTO 400 Header Selection Help - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-19-2011, 07:32 PM Thread Starter
Guys,
I'm shopping for headers. My most important requirement is ground clearance. I'm lowering the car by 2 or 3 inches, so I don't want to be dragging pipes...
Does anyone have any experience with this?
Many thanks,
FastMonty is offline
post #2 of 12 (permalink) Old 05-19-2011, 08:28 PM
Quoted: 98 Post(s)
I recommend the repop HO manifolds. They work, don't leak, and don't have clearance problems.
post #3 of 12 (permalink) Old 05-19-2011, 09:17 PM
68greengoat's Avatar
I agree with Jeff, ram air is the way to go. Just pic your poison, round or d-port. Here's an example.
High Performance Automotive Componentry
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 12 (permalink) Old 05-19-2011, 09:25 PM
X3.....or Doug's Headers
Eric Animal is offline
post #5 of 12 (permalink) Old 05-20-2011, 07:26 AM
Originally Posted by FastMonty View Post
Guys,
I'm going with Doug's on my 69, but I can't speak to ground clearance issues yet since my car isn't done yet.
I've also heard some very good reports on both the fit and finish of Mad Dog Headers. Had I known about them before I bought my Doug's, I would have given them serious consideration.
I'd have to agree with the others though who've encouraged the "Ram Air" style manifolds. They give up a little in terms of performance, but they're significantly more "trouble free" than headers.
post #6 of 12 (permalink) Old 05-20-2011, 10:07 AM Thread Starter
Bear,
Again, thanks for the great input. I'll check out the Mad Dog headers. If anyone else is interested, it looks like Hedman Hedders makes a "shorty" version. Which, I'd imagine has better flow than a Ram Air manifold, but not quite as good as full length headers.
I'm very interested to hear about your ground clearance, when you know what it is... or, if you look from the side, does it currently hang lower than the frame?
Thanks again,
post #7 of 12 (permalink) Old 05-20-2011, 10:48 AM
I was curious about that, so I snapped a couple photos with my phone. They do indeed hang down some, but then so too do the mufflers and the rest of the system. I might be able to pull the mufflers and everything up a little bit, but the flanges on the X-pipe dumps are already up against the floor so they're as high as they're going to get.
ID:	11176   Click image for larger version
post #8 of 12 (permalink) Old 05-20-2011, 10:57 AM Thread Starter
Bear,
I have to say, the pictures you've posted, both on the rear frame and the side view of your headers have saved me about 40 hours of work, just this morning. I really appreciate the help.
I'm surprised about the header drop, in a good way, I thought it would be a lot worse.
What exhaust are you running?
post #9 of 12 (permalink) Old 05-20-2011, 11:19 AM
Thanks for the kind words. I'm running a Pypes XGA11R, I think? I may not have the part number exactly right, but it's a header-back system, 2 1/2" stainless tube all the way to the bumper, a pair of their RacePro mufflers, and the X-change crossover that has dumps.
I'll attach some better photos of it. After I got it mostly fit the way I wanted, I dropped everything from the mufflers forward and welded the joints to make sure it doesn't leak and also to ditch the clamps so it could go a little tighter to the floor. I ordered a pair of their electric cutouts today I'm going to try to make a control bracket for the switch that looks like the one for the short-lived 70 Vacuum Operated Exhaust option and mount it on my Ram Air control bracket, like the one in the commercial.
ID:	11178   Click image for larger version
post #10 of 12 (permalink) Old 05-20-2011, 12:23 PM
"Shortie" headers are worthless. They're strictly for 'bragging rights". Headers are used to make horsepower. Without the longer tubes and good "collectors", they're not even AS GOOD as the factory-engineered HO manifolds. Factory "performance" cars of the '90s and '00s have "shorties", true enough. They (manufacturers) realized they were cheaper to make than really good cast iron manifolds (like HOs), and would last "long enough" to get out of warranty. They did NOT start using them for superior power.
If power is more important than looks and/or ground clearance, headers are the way to go. The Mad Dogs are a bit "tighter" to the body than the Doug's. Hooker makes the most power. "Ease of installation" is also a "non-factor". Power is power. If you want it, you gotta "do the leg work". You do what ya gotta do!
Jim
Mr. P-Body is offline
Cam selection help OrbitOrange 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 10 04-21-2011 11:15 PM
Need help with cam selection biffman Engine Discussions 16 10-01-2009 08:10 AM
'05 GTO cam install & selection question cat1055man Engine Discussions 45 12-24-2005 05:07 PM
