69 gto fuel return line - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-14-2011, 09:31 AM Thread Starter
The car has two stock fuel lines, but the fuel pump on the new motor only has one inlet. Do I need the return line or can i just run the single feed line with no return to the tank? Will I need a vented gas cap if I plug the line? Thanks
A69GTO is offline
post #2 of 3 (permalink) Old 11-14-2011, 10:20 AM
You can run a single and plug the return, if you still have the factory tank and setup it has its own vents already so you won't need a different cap. If you run into vapor lock or hot start problems later in the heat of the summer, then you might consider either changing the pump for one that has provisions for the return, or running a fuel pressure regulator and connecting that to the return.
post #3 of 3 (permalink) Old 11-14-2011, 11:10 AM Thread Starter
Thanks for the reply, I appreciate it
A69GTO is offline
67 GTO Fuel Line RGF 67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-28-2012 09:55 AM
Need fuel line dr68 1964-1974 Tempest, Lemans & GTO General Discussion 0 08-08-2011 12:04 PM
Fuel line @ pump jzegowitz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-26-2010 11:17 AM
66 GTO fuel line DRD57 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 12-03-2009 07:34 PM
New Fuel Line? coolhandgoat Service, Maintenance and Technical Discussion 4 04-09-2007 01:22 PM
