69 GTO Gas Leak - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-20-2014, 01:12 PM Thread Starter
69 GTO Gas Leak
When I accelerate quickly gas leaks out of the tank at the back behind the license plate. I've tried different gas caps and it still leaks. Not drops of gas but a stream. I probably lose a gallon of gas out the back for every full tank. Any suggestions?
Badboyrams is offline
post #2 of 9 (permalink) Old 07-20-2014, 01:17 PM
Check to make sure your vent is connected properly. There should be a flexible hose that connects to the side of the filler neck and connects to a vent tube that goes up above the filler neck, makes a loop, and comes back down. Losing fuel like that on acceleration just about has to be coming from one of three places:
1) Around the gas cap.
2) Through that vent.
3) The filler neck itself is leaking.
post #3 of 9 (permalink) Old 07-20-2014, 02:50 PM Thread Starter
I know it's coming from around the gas cap & I've tried a vented gas cap & I have a non-vented on it now. It still leaks no matter which one I use.
post #4 of 9 (permalink) Old 07-20-2014, 03:54 PM
Then I would say either the seal on the caps are bad or the end of the filler neck is not flat. Did you check the vent tube?
post #5 of 9 (permalink) Old 07-20-2014, 05:06 PM Thread Starter
The caps I've tried were new. Not 100% sure the filler tube is flat. But I can tell it's coming from the bottom.
post #6 of 9 (permalink) Old 07-20-2014, 05:08 PM Thread Starter
Gas leak
The bottom of either the cap or the filler tube.
post #7 of 9 (permalink) Old 07-20-2014, 06:05 PM
pjw1967's Avatar
These are photos on my '67 vent tube. If you have one, maybe the hose is oof? That would explain it. Very hard to see.
pjw1967 is offline
post #8 of 9 (permalink) Old 07-22-2014, 08:00 PM
jmt455's Avatar
Vent X2
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #9 of 9 (permalink) Old 07-25-2014, 07:32 PM
kilkm68's Avatar
My car did the same thing when I first got it. It was the vent hose. Make sure it loops up above the filler neck and it doesn't have a hole in it.
kilkm68 is offline
Gas leak. This is odd..... 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-07-2012 08:20 PM
gas leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-08-2011 11:37 AM
