69 GTO Jack Storage Placement - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-23-2016, 05:16 PM Thread Starter
EdR
Hi. Can anyone tell me if I have the Jack placement correct for a 69 GTO?
EdR is offline
post #2 of 9 (permalink) Old 01-23-2016, 10:42 PM
Does this help?
05GTO is offline
post #3 of 9 (permalink) Old 01-24-2016, 10:28 AM Thread Starter
EdR
Thanks for the diagram. Not sure if it helps. If I understand correctly the Jack goes inside the floor bracket which looks correct to me. But then it seems the Jack is to long for the truck? See pictures. Maybe I have the wrong Jack for the car?
ID:	70465   Click image for larger version
ID:	70473   Click image for larger version
EdR is offline
post #4 of 9 (permalink) Old 01-24-2016, 03:21 PM Thread Starter
EdR
The column length on this jack is 36 5/8". Can anyone provide the column length of a jack they have in a 1969 goat?
EdR is offline
post #5 of 9 (permalink) Old 01-27-2016, 08:54 PM
"Correct" storage. Position the jack mechanism so that its near the middle of the jack "column". One end of the column fits into that angle that's visible in the upper corner of your first photo. The jack mechanism should be positioned so that it will be held down by the tire. The hooked end of the bolt goes into that bracket and up through the center of the spare. The jack foot place goes upside down onto the spare (which is also 'upside down' - brake side up) with the stem of the bolt also going through the jack foot plate --- everything held down by the big wing nut. There's also supposed to be a piece of rubber on the jack column that the lug wrench slides into.
Yeah, from your second set of photos, you've got the wrong jack. The column is too long to fit where it's supposed to.
post #6 of 9 (permalink) Old 01-29-2016, 01:31 PM Thread Starter
EdR
Thanks Bear. I got a replacement Jack that's 34 3/8" long. Still doesn't really lay flat. I'm assuming its supposed to. I'm tempted to just cut an inch off the end of it. Do you have a jack that fits properly? If you do how long is the column?
EdR is offline
post #7 of 9 (permalink) Old 01-29-2016, 02:12 PM Thread Starter
EdR
If I put the jack to the left of the bracket it fits pretty well.
If I put it in the bracket its too long to lay flat.
https://im1.shutterfly.com/media/47a...D720/ry%3D480/
EdR is offline
post #8 of 9 (permalink) Old 02-01-2016, 02:13 PM Thread Starter
EdR
Anyone?
EdR is offline
post #9 of 9 (permalink) Old 09-25-2016, 04:00 PM
Quoted: 14 Post(s)
I'm going through this with my 69. The jack I just bought is 32-5/16 in length. It's going in next week. I'll let you know how it goes.
greenjudge69 is offline
'68 Jack Usage and Storage Decal Placement wishihaditback 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-10-2015 09:00 AM
Getting GTO out of storage brendan4862 2004-2006 GTO General Discussion 13 04-07-2014 08:43 PM
jack instruction label correct placement 1964 gto daveh70 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 14 09-16-2012 10:32 AM
GTO in storage for 2 1/2+ years? GM4life 2004-2006 GTO General Discussion 15 02-27-2011 05:32 PM
Best place for floor jack/jack stands? TC71Lemans 1964-1974 Tempest, Lemans & GTO General Discussion 4 03-24-2009 03:00 PM
